Question about LG 24 in. LDF 7811 Built-in Dishwasher
My Lg Diswasher is making a dry whinning noise all the way through while motor is running How can i tell if its the motor or the impeller Kim
  • 192 Answers
Hi . The LG motor has 2 bearings of LOW Korean quality in the motor. The 2 can be replaced by SKF 608 bearings and once the motor is out can be done for just a few bucks. I have just opened 2 motors and in both cases it's the front bearing to the impeller that makes this grinding noise.
Posted on May 11, 2013
    Scholar:
  • 62 Answers
The problem is indeed in the wash motor bearing.
unfortunately most motors come with complete with impeller.
You didnt mention model number so unfortunately i cannot give you a re[placement cost.
Regards
aardvark Repairs
aardvark.repairs@btinternet.com
Posted on Nov 17, 2009
WHY DISHWASHER MAKES A WHINNING NOISE
If the dishwasher is making a loud whining noise, the drain pump or motor bearings are defective, the drain impeller or wash impeller might have worn out. All these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Jul 14, 2014 | LG LDF6810ST Stainless Steel Built-in...
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Abused by family member left water in basin. motor makes noise
Hi, If water was left in the tub when it was being used for wet pick-up, and wasn't emptied before using again for dry, you have sucked water up in and on motor windings. About the only thing you can do at this point, is to let the motor dry for a day or so and see if it continues. Check to see if something didn't get caught in the motor that may be making this noise. I hate to tell you but you may loose the motor. Time will tell. If you still have good suction, I would continue to use it until it dies on you. Check for any debri and dry it good. Keep me posted.
Best of luck to you,
Shastalaker7
Mar 01, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I have a LG diawsher, model # LDS5811ST that is
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
LE means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
You also should remove the door panel and check for a broken wire (usually the blue one)
If all the wiring checks out - it is most likely a broken or locked up impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | LG Dishwashers
I have an LG Diswasher LDS5811BB Bought in 2006
LE is a motor error The Motor is working abnormally.
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Aug 29, 2009 | LG Dishwashers
My LG makes noise during operation.
The only way to access the motor either the drain motor or the wash motor is to pull the diswasher out, invert the whole thing, remove the access pannels. If you are going to remove the entire sump assembly, be real careful as you remove the screws, because the law of gravity promises to crash the sump down onto the "top" of the diswasher.
The Parts waranty is 24 months. But with the motor being repaired by an (factory authorized?) you may be able to get LG to cough one up.
Look carefully at the failed motor, write down the horse power and amps spec. Compare it to the new one. You should see a higher horsepower version. Good Luck.
Also, if you have _ever_ had problems with water leaking from the front door or the dishes dry poorly, get back to me with your model and serial number. Could have some good news for you.
Mar 31, 2009 | LG LDF6810 Built-in Dishwasher
LG Wash-Dry WD14700RD pump or solenoid noise
this is indicative of a bad impeller in the drain pump motor, it will most likely need replaced.
Make sure you check the drain filter for any loose coins or articles that may have been trapped and hitting against the drain pump impeller. If it is clear then the motor is indeed bad. Hope this helps, please rate my solution.
Jan 07, 2009 | LG WD-1280FHD Front Load Washer
Motor removal
I am having a same problem. You can open dishwasher sump assembly from inside the dishwasher and check if something is blocking white impeller. I tried to open impeller and sheared screw head as I did't realized it is left handed screw. Even after cleaning impeller you still get problem, you need to check from bottom and see if something is stuck there. If all right and you are still getting error then it is time to replace motor. In my case I ordered entire sump assembly as my seals were also wornout. Sump assy cost $113 on Sears part direct.
Dec 30, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
LG 24 in. LDF 7811 Built-in Dishwasher Logo
434 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
