Question about Dishwashers
How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
Spray arm is plugged, and I can't figure out how to get it off to clean it.
Also, what causes this? Is there a filter somewhere that needs to be cleaned?
  • 2 more comments
  • tom9718 Nov 10, 2008
    my upper spray arm has come off and I cannot see how to re-attach it. Can anyone help?
  • jackieoes Nov 28, 2008
    cannot remove upper arm
  • Anonymous Mar 12, 2014
    is there a tool that you use to remove the tower on the bottom spray arm maytag dishwasher
  • Anonymous Mar 15, 2014
    how to remove upper spray arm feed pipe
    Scholar:
  • 196 Answers
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
Posted on Jan 10, 2008
  • BENNYDRAKE May 09, 2011
    HOW DO YOU CLEAN IT OUT? DO THEY COME APART IN HALF?
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Top spray arm doesn't spin
The filters are probably plugged. This will require removing the lower spray arm and cleaning the screens or its possible your not getting enough water in the dishwasher which will cause th upper spray arm to not turn
Feb 10, 2018 | Maytag Dishwashers
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Whirlpool Dishwasher Model GU1200XT
Check the upper spray arm for debris plugging the spray holes, if clean then pull off lower spray arm and filter screen, and clean and remove any debris found in the sump, check the disposal blades as well. You will need a torx style screwdriver to remove the sump screen on this unit. You can buy a set for under $10 at your local hardware store.
Feb 22, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Maytag MDB3100 Soap Dispenser Problem?
Remove each arm and inspect the small spray holes for plugging. Use a vacuum in the center hole and poke out each plugged hole. Unless your vacuum allows wet pick-up, make sure the arm is dry first. Try using a capsule type of detergent instead of liquid. You might have to tear down the lower spray arm assembly to the deck to clean the large screen which may be plugged with water/food deposits. Use hot water, detergent and white vinegar to clean the screen. Hope this helps!
Jun 12, 2008 | Maytag MDB3100 Dishwasher
How to remove Sprayer Arms
metal sleeves at the end of the lower spray arm?? dont remove them they only protect from hitting against heate and melting. should be a center thumbscrew in spray arm loosen that nut and should come right out, pokin with wire or toothpik willwill clear joles but you gotta remoe the debris from the arm other wise first run will shoot right back nto holes
Feb 22, 2008 | Jet Tech Systems STEALTH Dishwasher
Clogged
Richard, There should be a spin nut just above the spray arm that attaches to the spray arm hose. Unscrew this and it should come off. Catriver...post back.
Sep 10, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwashers Logo
2,315 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
