Question about OKI C9600n Led Printer
The display is showing Service Call 132:Fatal
The display is showing 'Service Call 132:Fatal Error'
We have gotten around this problem previously by switching the printer off and leaving it for a few minutes but this has not worked this time.
I solved this problem easily (Once I found it!)..open lid, locate where the top section bright metal lugs contact with copper leaf contacts at the front of the base unit and clean them with some fine emery paper or gently with small flat screwdriver... mine had a bit of toner dust and a tiny carbon deposit which was preventing the circuit being made. This showed the fatal error 132 and you may notice on start up that the normal rotation noises within the machine were silent too. Worked for me. Problem arose after Xmas break when machine had been stood for a few weeks. Good Luck! Bryan at Pinewood Studio Manchester.
Posted on Jan 11, 2010
  • 2,973 Answers
In that case, uninstall the printer from the Control Panel->Printers and after a reboot reinstall the drivers. That should solve your problem.
Posted on Nov 17, 2009
What should I do when the Display says Service call 132:Error
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
May 27, 2014 | OKI C5100n Laser Printer
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
Greetings,
FATAL ERROR CODE : unit is unable to perform requested operation
No reset or fix for that problem.
New camcorder or repair - get a quote for repair and compare price for a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 20, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Fatal Error 121
Hi and welcome to Fixya!
"Fatal Error" on your printer display or status monitor simply means a problem has occurred requiring action to clear. Fatal Error explanations are not usually found in the manual. You can check the list of error codes from the link below:
http://www.c8600.co.uk/index.asp?printername=C8600&menumode=0&content=errorcodes
RECOMMENDED STEPS:
First, try turning off your printer then turning it back on. If you're still getting the same error message, make sure the printer is plugged directly into the wall. Often, the issue is power-related.
If the problem persists, write down the message including the 3-digit error code number and send an email to "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers scrolling across the display after the 3-digit error code, write it down and report them when calling or emailing Customer Support.
Jun 29, 2011 | OKI C5800Ldn Led Printer
How do i fix a 131 fatal error?
FATAL ERROR 131, 132, 133 OR 134 ON THE DISPLAY ON POWER-UP
CAUSE - ONE OF THE LED PRINT HEADS IS DISCONNECTED
SOLUTION - RECONNECT THE RIBBON CABLE TO THE PRINT HEAD
Just for information, the led print heads are the four assemblies that hang down from the lid of the machine when you open it.
Sometimes they become unclipped, and the ribbon cables can get pulled loose.
131 probably means the front one.
Mar 04, 2011 | Office Equipment & Supplies
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
World of Warcraft ERROR #134 (0x85100086)
This is what worked for me –
Made a copy of the file expansion-speech-enUS.MPQ changed the copied file name to speech-enUS.MPQ, both files are in the same folder.
This problem hunted me for quite a while, and this simple solution was a gr8 relief.
Aug 25, 2008 | Blizzard Entertainment World of Warcraft...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error
Fatal Error K (for BLACK) - Black toner or drum problem, Drum life exceeded? Display would of said black drum near life before failing.
May 15, 2007 | OKI C5100n Laser Printer
OKI C9600n Led Printer Logo
4,261 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
