Rubber door seal problem
I have a Whirlpool AWG 7661 front loading washing machine. The rubber door seal has come away from the drum allowing washing to pick up dirt. Cannot find a way of refixing seal. Help!
    Scholar:
  • 62 Answers
In my 13.5 years experience I have never experienced a door seal coming away from the drum!!!
If this was the case then you would have a major water leak!!!
Does the door seal look twisted at all?
Have a good look at the seal. Is there any black mold on the seal?
If the seal has come off then I would need to guide you through the refit process.
Please email me on: aardvark.repairs@btinternet.com and I will email you back my phone number
Regards
Aardvark Repairs
Posted on Nov 17, 2009
My washing machine is leaking
Through the door? Where is it coming from?
If door, check the rubber seals are ok and not torn, broken or perished.
If elsewhere, could be a break in the drum or a water pipe loose
Oct 14, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How do I change the rubber sleeve between the door and the drum on an awg 5122
Ji,,usually with these machines you have to take off the toplid of the machine,fixed at the back with 2 or 3 screws,,then you will see a stell band/circlip going round the lip of the innerface of thedrum.you have to reach in from the top or from the bottom with a screwdriver to undo the bolt holding both ends of the circlip/band togetherthe rubber should lift away from the lip,,then remove from the front opening at door..replacement is in reversal order,,making sue appliance is unplugged from mains before any work carried out.Staff at shop where replacement rubber purchased should be able to help with any other queries,,,hope this helps,,
Jul 05, 2011 | Whirlpool AWG5122 Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a Whirlpoool 6th sense front loader. The drum is constantly rubbing against the front rubber seal which constantly whines and screams. Is there an easy fix???? We reported this to the service centre...
Few things to check as the gap tollarance between the drum and rubber seal is small. Open door and turn drum by hand. Look carefully and see if the drum has an uneven wobble which is touching the rubber. If it has, you need to send the machine back or frplace the drum. Sometimes the rubber is installed slightly off centre which alters the correct rotation gap. Seal would need to be removed and realligned correctly.(I would check the drum for any signs of not being truly round)
Aug 15, 2010 | Whirlpool AWM8143 Front Load Washer
Bought new rubber seal for whirlpool but no instructions how to fit.has 2 wire rings front and back of seal so how do you fit them around the new seal. do you work from the back of rubber seal first ie...
this is why we are paid to do the tricky stuff. Ok, remove the lid then open the door. look for the front pring loaded wire then remove. Pull front of seal off ridge then bend it back into the tub so it allows you to work easier. you will now see a second large ring holding the other end of the seat to the tub. remove it then pull the faulty seal out. Follow same proceedure putting it back. careful not to tear boot as it is silicon.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Oct 12, 2008 | Whirlpool Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
