Question about Acer TravelMate 212T Notebook
My acer travelmate 212T Laptop body/casing is crack & start to fall apart. plastic turn brittle. I'm looking for body/casing, second hand is good enought. other than that it's still working. If you guys have the same model which is faulty please let me know
How I can reset bios psw my noitebook travelmate 212t acer? please help me!
Is there a reason to reset the password, I think Acer have put it there to stop people from messing, because they would have fine tuned it. You will have to get in touch with Acer.
Sometimes under the ram slots there is a round flat battery, if there is, take it out and leave for a minute, then reinsert it.
Sorry I can't help any more.
Regards - Anthony
Feb 07, 2010 | Acer TravelMate 212T Notebook
Corrupt files on acer travelmate 212t
what player you are using try playing music files on different player or download VLC player it will play better
Sep 11, 2009 | Acer TravelMate 212T Notebook
How do i change the CMOS battery on an Acer travelmate 212T?
It may well be similar to the procedure for the Travelmate 201T, for which I happen to have produced a YouTube video showing the procedure... hope this helps!
May 30, 2009 | Acer TravelMate 212T Notebook
I need to open my Acer laptop case to solder to power switch
this may not be your exact model, but should give you a good general idea on how to get inside. The key is prying up the top strip, that seems like it is going to break. Use something plastic or wood if possible. A screwdriver will leave marks.
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Apr 02, 2009 | Acer TravelMate 512T Notebook
Soft drivers
All drivers for this software can be located at the following address:
http://www.acersupport.com/notebook/html/tm210_dl.html
These drivers are for all notebooks in the 210 series, including the 212txv.
Mar 18, 2009 | Acer TravelMate 212T Notebook
Cracked case
Hi there.
You can order spare parts from Acer themselves or alternatively look on Ebay for spare plastics.
It sounds like you need the lid face and bezel (plastic that surrounds the screen), as for disassembley i'm afraid its trial and error as you may have to take the laptop apart to replace the plastics.
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Acer Aspire 3680 Notebook
Acer travelmate 212t problem
It sounds like video card problem. Bring it to a repair shop.
Dec 10, 2008 | Acer TravelMate 212T Notebook
Bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Sep 12, 2008 | Acer TravelMate 2300 Notebook
Wont start up
Sounds like you have a CD or DVD in your CD or DVD drive, or if you have a floppy drive, a floppy in it.
If these are empty, Put in your recovery CD and see if it reads that.
Jul 17, 2008 | Acer TravelMate 212T Notebook
No picture and no sound
no picture and no sound means that either the operating system is not installed, the motherboard or hard disc drive is faulty, hard to say where to start as you don't know the last thing that happened to it to start the diagnosis. If you don't own a hdd usb2 to 3.5" ide cable to firstly check the hard drive, you will need to take to a repairer and illiminate as you go along.
May 21, 2007 | Acer TravelMate 212T Notebook
Acer TravelMate 212T Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
