Question about HP Hewlett Packard LaserJet 1600 Printer
HP color laserjet 1600 image misalignment problem where the black
HP color laserjet 1600 problem where the black image is misaligned with the color image . sometimes even get two misaligned black images .Help please /
  • 4 Answers
Try to calibrate your printer at the print quality menu
Posted on Aug 28, 2012
    Problem Solver:
  • 6 Answers
Plz check ur catride max problem willbe with the catriade
Posted on Nov 17, 2009
Why are the colors on printouts not overlapping?
You probably need to run an alignment procedure. See the link below.
Align Print Heads On An HP Laserjet 1600
Sep 04, 2014 | HP Color LaserJet 1600
My hp CLJ 1600 misaligment colors black go left yellow and cyan are ok and magenta goes right. I try calibration no effect
Hi bojan,
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
HP Printer Support
Feb 26, 2014 | HP Hewlett Packard LaserJet 1600 Printer
Colors are not ligned up even after calibrating. Black and white prints fine. In addition, the transfer sheet has a streak of blue powder on one side which causes streaks on the paper. I know how to...
The blue streak is likely caused by a bad cyan cartridge, not a bad belt. That will clean off after you replace the cartridge. The misalignment problem sometimes requires 3 complete full calibration cycles to eliminate the error.
Apr 21, 2011 | HP LaserJet 4650n Printer
HeLp! My HP CM2320nf MFP is printing blurry!
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
Apr 29, 2010 | HP Laserjet CM2320nf All-In-One Color...
2600n faded print on both left and right side.(word doc, no images) not using color black print only.
Is the cartridge an original HP or an inexpensive compatible? The black cartridge could be out of toner. Not a common defect for the Q6000A cartridge though. If it is a poor quality compatible the defect may be the result of a misaligned internal component. Either way replacing the black cartridge should resolve the issue.
Jan 18, 2010 | HP Color LaserJet 2600n Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP 2605dn Black prints 1/8" offset to left. Colors do register
Missalignment problems ae not uncommon with this series of printer.
The cause is one of the sensors (which are used for calibration and alignment) on the transfer belt, is faulty.
These sensors are NOT availale, and replacement of the transfer belt is the solution.
Transfer belt replacement on these printers requires quite a bit of dismantling, its not considered to be a user replacable consumable.
Black and color misaligned
u can try secondary service menu options. press menu then press cancel & left arrow simultaniously.now u can get a 2ndary service menu.
Sep 25, 2009 | HP Office Equipment & Supplies
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Oct 07, 2007 | HP Color LaserJet 2600n Printer
HP Hewlett Packard LaserJet 1600 Printer Logo
928 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
