Question about Compaq Presario M2000 Notebook
When press the ON baton only the lights of num lk and caps lock blinks, no booting
Replace your pc
Posted on Jan 07, 2010
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
My dell d600 latitude laptop indicates a lock button in the top icons and cant procede from there
purple function key next to the ctrl key
press that down and hold
press the num lock (toggle)
press the scroll lk (toggle)
press white cap lock only
See if any of these change the lighted lock indicator.
I assume that was what you mentioned in a focus of the request
Aug 19, 2010 | Dell Latitude D600 Notebook
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
There is no key for numlock on my Dell studio 15 keyboard
The num lock key is labeled as 'Num Lk' on the Dell Studio 15 keyboard. It is located above the =/+ key next to backspace.
To activate num lock, you cannot just press the button. You have to make sure the num lock light is on and then hold down Fn while using the numpad.
Hope this helps,
Tiger720
Sep 02, 2009 | Dell Studio 15 Laptop
Boots up with function key locked. Can't type normally.
It sounds like your NumLock key is on. Try pressing the FN key and the NumLock keys at the same time. This should straighten things out.
Aug 17, 2009 | Compaq Presario X1000 Notebook
Number 9 inside a lock symbol on the keyboard and computer unresponsive
press num lock /num LK/scroll Lk.Find any of those key on your keyboard.it solve your problem.If .in Dell Latitude D600 the num lock/num Lk/scroll Lk is above F11 key.
  • after solve it,don't forget to visit me here
Jun 10, 2009 | Dell 0Y3740 Keyboard
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
