Question about ASUS M2N-MX Motherboard
New build pc no boot... black screen
Os windows sp2
mobo asus m2n68-am plus...Onboard graphics
cpu amd athlon64x2
hd hitachi 250gb
ram Kingston 1 gb
psu dtech 450w
thanks in advance for any and all help.
I put this together this morning booted it outside the case bios came up ok.so I mounted it in the case...tested again bios came up ok..hooked up the hd started loading windows xp sp2 it quit copying files about 50% of the way in..I hit esc a couple times to try and get it started..no luck so I hit F3...quit setup and the computer went to reboot
came back black screen...I changed the ram to a known working one,no luck...I went and got a new dtech 450w power supply and installed that...still no luck...I took out the cpu...to see if it it would boot to error screen ...no luck...any Ideas would surely be appreciated
Again thanks for any and all help
  • threetyme626 Nov 17, 2009
    Thanks Vojvodabudva ...i tried the battery removal(kept it out 20mins)..removed the power cord and held the power on button for a few seconds to remove any residual power...I also flashed the cmos with the jumper...no luck....Then I tried a graphics card i know works still nothing...I am stumped...any and all help is sought...thanks again
    Champion:
  • 206 Answers
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Posted on Nov 17, 2009
Assassins creed 3 on dell inspiron 640m
CPU: 2.66 GHz Intel Core 2 Duo E8200 or 2.66 GHz AMD Athlon II X4 620 CPU Speed: Info RAM: 2 GB
Not enough RAM!
OS: Windows Vista (SP2) / Windows 7 (SP1) / Windows 8 Video Card: 512 MB DirectX 9.0c-compliant with Shader Model 4.0 or higher (GeForce 8800 GT or Radeon HD 4850) Sound Card: Yes Free Disk Space: 17 GB
Jan 11, 2014 | Dell Inspiron 640m Notebook
Hello, i believe this is an ASUS M2N68-AM PLUS issue but it may be my graphics card. problem: after installing an Nvidia GT 240 PCI-E graphics card, the pc boots but there is NO display (while using...
hi anderson4584, i have same problem with the same configuration,.. if you find any solution so please inform me at this email-id pardeep3@gmail.com
Oct 10, 2010 | ASUS M2N-MX Motherboard
Appropriate and complete drivers
go to the compaq website and locate your models drivers
Apr 09, 2010 | Compaq Presario Notebook
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
NFORCE6M-A V:2.0
8GB PATRIOT
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
AND 4GB OF DDR3 1066 RAM COMPATIBLE WITH MOBO $40+/-
THE ONBOARD VIDEO IS CAPABLE OF USING 700MB
OF RAM...RGB/DVI OUT.
HOPE THIS HELPS.
Sep 12, 2009 | Asrock K7VT2 Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
I want to build my own desktop game machine, i want to run crysis at least at 1440x900 screen resolution, and the cost of the case plus internal componenets needs to be sub 1000 uk pounds. what mother...
I would suggest a
Gigabyte S-series AM2 (GA-MA69GM-S2H model to be exact)
AMD Phenom 9700+ Quad-Core CPU
4Gig 9600 Kingstone RAM with heatsinks
The mobo i mentioned comes with HD onboard audio as well.
Oct 22, 2008 | Computers & Internet
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-MX Motherboard Logo
369 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
