I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without cable and I am waiting to have a satelite system installed, I installed the TV on the wall and hooked rabbit ears to it to see if it would be ok and the yellow vertical stripe appeared. What is it and what will make it go away?
  • MaWe
    MaWe Jun 30, 2017
    Hi lylemorris_2, does the vertical band appear even when you disconnect the antenna und just enter the setup mode?
    Top Expert:
  • Televison & ... Master
  • 26,089 Answers
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Posted on Jun 30, 2017
Drummernick
  • 440 Answers
SOURCE: Black Vertical Stripe
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Posted on Feb 03, 2008
thecritter
  • 29 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Posted on Mar 30, 2008
SOURCE: reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
Posted on May 30, 2008
SOURCE: philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Posted on Jul 22, 2008
  • 3 Answers
Check these videos for repair instructions for black lines.
Just requires some soldering.
Video 1 / Part 1
http://www.youtube.com/watch?v=9NPobj0_GSo
Video 1 / Part 2
http://www.youtube.com/watch?v=ITd6Ahdi4s0
Video 2
http://www.youtube.com/watch?v=qBpg77ZzFFk
Posted on Feb 09, 2009
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
