Question about Hotpoint Aquarius WMA42 Front Load Washer
I think I may have something behind the drum. How
I think I may have something behind the drum. How can I check?
    Scholar:
  • 62 Answers
Hi.
Unfortunately this will neeed a service engineer to strip the machine down to locate item inside drum.
Regards
aardvark Repairs
Posted on Nov 17, 2009
I have the same exact problem! Machine eating change & clanking?
try taking the heater element out and using aold coat hanger fish for the coin
Sep 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
How to remove the drum
before you take the drum out please do one simple check to see if the bearing have worn out.open the door and lift the silver drum inside up an down now if you ear a knocking noise or feel a knocking vibration then it definately the bearrings have gone.
Jul 06, 2009 | Washing Machines
Scrapping sound
likely something else like bra wire sticking up from drain hose rubbing basket. remove front kick panel or rear panel and remove large hose from bottom of tub. clip usually positioned in rear. if unit with heater then heater and clip can be felt inside tub. check inside hose
Apr 26, 2009 | Kenmore HE2 Plus Front Load Washer
Loud noise from dryer
Good Afternoon,
If a toothbrush went into the dryer it would have to remain in the drum. There are no outlets large enough for a toothbrush to fit through. Can you tell where the noise is coming from? Also, check the drum good, the toothbrush could be hiding behind one of the ears in the drum and you probably can't see it. Try running your hand behind the ears inside the drum, it just might be there! I hope this will help you and thank you for using FixYa!
Mar 22, 2009 | Amana NDE2335AY Electric Dryer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer (He3t) front load
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Front loader washing machine - noisy spin cycle
A service engineer told me he thought there was a piece of wire caught behind drum and to see if it worked its way out. It hasn't because I don't think he's right. On spin the noise is sometimes so loud it sounds like the bearings have gone. Today I removed the fluff filter and discovered what appears to be shreaded grey plastic. If I can get a copy of the machine spec I might be able to discover where this has come from. Sorry this is not a solution. But as your symptoms are so similar check your filter and see if its full of shreaded plastic.
Sep 23, 2007 | Electrolux EW1000i Front Load Washer
Hotpoint WMA56 - Puts holes in washing
could well be a bra wire. the easiest way to check is: remove small cover on rear bottom of machine. you will see the heater on rhs. loosen centre nut and prise heater out. shine a torch down the hole and turn the drum slowly and any foreign object should be apparant
Jun 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
