Question about Nokia N80 Cellular Phone
I tried to update my nokia n80.after the update
I tried to update my nokia n80 with the help of nokia pc suite.after the update was done it did not restart.please help me
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Tip
Nokia Firmware Updates
Hello, this is a tutorial explaining which steps you should follow in order to perform a firmware update or "Flash" on you mobile phone.<br /><br />What you will need to do this Procedure:<br /><br /> <ul> <li>USB data cable</li> <li>Nokia PC Suit</li> <li>Nokia Software updater</li></ul>In this tip the link for both PC suit and Updater will be provider for download.<br /><br /><img src="lock123.jpg" /><br /><br /><span>Step 1:</span><br /><br />You will need to <span>backup</span> all the data on your phone before you start doing anything else. You can either do the backup by following either the steps below:<br /><br /> <ul> <li>If you have a memory card in your phone, you can do the following: Tools&gt;Memory select options&gt;Backup phone memory. Once the backup is complete, remove the memory card from the phone.</li> <li>You will also be able to backup your phone using Nokia PC Suit. Once you have installed it, you will need to connect your Phone to your computer using the USB data cable. Once the phone and the computer is connected, you will have an option to backup the phone data.<br /></li></ul>At the links below, you will be able to download Nokia PC Suit and Nokia Software Updater.<br /><br /><a href="http://europe.nokia.com/support/download-software/nokia-pc-suite/download">Nokia PC Suit</a><br /><a href="http://europe.nokia.com/support/download-software/device-software-update">Nokia Software Updater</a> (To download the correct version for your phone, you will need top select your phone model)<br /><br /><br style="text-decoration: underline;" /><span>Step 2:</span><br style="font-weight: bold;" /><br />Before you start the actual firmware update, you will need to charge your phone, to ensure that the phone will not disconnect during the updating process. If the battery does not have the sufficient charge, the process will not start.<br /><br /><br /><span>Step 3:</span><br /><br />Since Nokia PC suite is already installed, you will now need to install Nokia Software Updater. Once the install is done, you might need to check your Firewall settings to ensure that there will be no data blocked or filtered during this process. Click <a href="http://www.microsoft.com/windowsxp/using/networking/security/winfirewall.mspx">HERE </a>to see how to set firewall settings.<br /><br /><br /><span>Step 4:</span><br /><br />From now on it's really simple, just follow the guide and you'll be fine. The whole updating process takes several minutes to complete, don't try to cancel it in the middle in any case, your risk damaging your phone. You will need your USB cable in this step.<br /><br /><img src="lock123_0.jpg" /><br /><br /><span>Step 5:</span><br /><br />Lastly you will need to restore the backed up data once the update is compete. Again, this can be done in two<br /><br /> <ul> <li>if you used a memory card for backup then you simply go to the <i>Tools</i> - <i>Memory</i> select <i>Options</i> - <i>Restore from card</i>; if you used Nokia PC Suite you have to connect your phone to the pc via <span>USB</span> cable, select Backup and Restore</li></ul>And then you are done.<br /><br />I really hope this can be of help. Please feel free to share your thought and advise.<br /><br />Kind regards<br />Lock123<br /><br /><br />
on Dec 10, 2010 | Cell Phones
My nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
The phone freeze if sending sms
probably software. go to nokia.com and download latest software to your n80 by using pc suite and your computer cable
Oct 17, 2009 | Nokia N80 Cellular Phone
I tryed to instll softwer update for my Nokia N80 throu PC Suite. Now I can't turn it on. it just say - system error. HELP please!!!
Formatting should solve the problem, if you consider , u ll lost the contacts.
here is how you can format the phone.
turn off the phone, press 3,*,call(green one) at a time and power on holding the keys ( it means finally 4 keys at a time, dnt laugh , it is way, phone can he hard formatted)
Try untill it askes for the time and country. Pressing 4 keys at a time is a bit tricky so, it is easy to miss one/two attempts, atleast i do.
Oct 09, 2009 | Nokia N80 Cellular Phone
Hi i have got a nokia n80 and i lost my security code help plzzzz
To format/hard reset your Nokia N80, try the following method: 1) *#7370#
2) Turn off the mobile device. Then press and hold “3′, the “Green button” and “*” - Turn on and keep holding until the phone fully restarts. If successfully, you’ll be asked to reenter the date, time, city, etc.
When resetting the phone it will ask for the phone lock code. The standard Nokia lock code for the N80(and possibly the other phones) is ‘12345′
Sep 21, 2009 | Nokia N80 Cellular Phone
My n80 doesn't appear on my computer
there is a problem in yur mob pin wher yu conec the data cable .. please chec tat nd repair tat if yu have 2.. den yur phon ll connec on ..
Jul 19, 2009 | Nokia N80 Cellular Phone
With my n95
most likely a software problem.
Go to the NOKIA web site and download the NOKIA Software Updater and update your software, go ahead with it even if it is the same version and don't worry about your warranty as it is a NOKIA update the warranty wont be affected.
BE SURE TO BACK UP YOUR DATA 1ST, EITHER USING THE NOKIA PC SUITE OR GOING INTO TOOLS, FIND MEMORY>PRESS OPTIONS>BACK UP PHONE MEMORY
After update is done you can restore from PC Suite or card to put everything back to the way it was without the problem.
Jan 31, 2009 | Nokia N95 Cellular Phone
Nokia N80 "phone lock code"
Hi have you tried 0000 thats usually the code that is stored when phone is new failing that you will need to get a flash lead and nokia softtware that scans the phone and gives you all the codes allowing you to change them but this is expensive to buy.
I have alot of nokia software but not sure if it works through usb lead as i use from computer then into black box then into phone as i have this as it works on all makes an model of phone if it can be done through the usb lead i can tell you where you can get this software from ok just give us a shout back
Mar 17, 2008 | Nokia N80 Cellular Phone
SMS PROBLEM WITH NOKIA N80
Try updating your software via the Nokia Software Updater, it sounds like a firmware problem.
Download it for free of the Nokia-Website.
Oct 10, 2007 | Nokia N80 Cellular Phone
Cell Phones Logo
54 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
