Question about Toshiba Satellite A100-S8111TD Notebook
When I plug my power supply in it doesn't register a/c power and when you press the on button the battery light flashes orange. I am not running laptop with a battery.
  • 979 Answers
Good day sir, hi, running a laptop without the battery is dangerous, it could damage the laptop, If the laptop is malfunctioning, have it checked by a service repair man, or bring it to your dealer for advice on the service of the power supply.
Posted on Nov 17, 2009
My Dell D600 laptop stopped working today. Coincidentally, I had just turned it off to try running a test on the RAM because the PC had been slow and locking up for the past month or so. Anyway, when I...
try this:
1- deattach the RAM , run the laptop without (RAM) you must hear som beeps
2- put the ram back again in the same slot
if it doesn't work try other slot
Feb 07, 2012 | Dell Computers & Internet
My dell inspiration 910 has just played up. it was working perfectly before and i was using dell speakers and my ipod, ipod was removed, and left it still pluged in and charging and noticed the orange...
This sound as though the power supply adapter needs replacement.
If you can find a compatible power supply adapter perhaps you can charge you laptop.
A company call Batteries Plus may be able to help or Ebay may have you adapter power supply if you do a search.
You may also contact Dell for support on this issue.
Some Dell power supply fail due to overheating.
you may also want to check the power supply connector.
Apr 24, 2011 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
It's an Acer Aspire One 110 running Windows XP. When battery is inserted or power supply plugged in, the green light on the power button comes on and as long as there is power going to the machine the...
Hi
Thank you for your query
It would seem you have a possible DCf jack problem, causing the mentioned issues
If the DC jack is faulty it can cause the problems mentioned above.
I would recommend that you book the laptop into a reputable PC shop for them to replace it
I hope this has been useful
Mar 16, 2010 | Computers & Internet
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
-Orange light on Power-up button stays lit. -No Video, just black screen. using AGP Video card TNT 32mb / Model CT5823 I've replaced the battery, double checked the cables, Power supply is good. Gatew
This is typical of a failed power supply. Look on the back of the power supply, there may be a red switch for input voltage. Unplug the power cord, flip that switch a few times and then plug the cable in and try again. If nothing changes, see if there's a small black button on the back of the power supply. If there is, unplug the power cable and press the button and hold it for 10-15 seconds. If an LED flashes or turns on, then plug the cable back in and try again. If this all fails, replace the power supply.
May 17, 2009 | Gateway Computers & Internet
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
