Question about Xerox DOCUMATE 510 Flatbed Scanner
Color streaks on ADF feed.
When using ADF for multi page feed, all but the last page have a color steak at the bottom of the page. Works fine when sigle page feed, and on flatbed.
  • 4LostInSpace Jan 11, 2008
    I had done the items you suggested already. The problem was that the user had not changed the scan image size to 8.5x11.0 after scanning a legal size document. Set correct size and no more streaks.
    President:
  • 2,072 Answers
Sounds like a dirty seal glass.
The small srtip of glass on the left side of the scanner.
Clean it well.
If there is no streak when scanning on the flad bed portion, then there is most likely a small almost non visible contaminant on the seal glass.
Use a regular piece of 20 pound paper crumpled with some glass cleaner or alcohol and clean that glass thorughly
Posted on Jan 11, 2008
  • Rick Kasper Jan 11, 2008
    Glad you have it figured out. Yeah I was thinking of a streak in the other direction.
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
My Canon MF4150 multifunction device started displaying streaks (or black vertical lines) on pages scanned via the ADF. These streaks appear when scanning from Windows 7 (64bit home premium) as well as...
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Dec 28, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Dark black streaks accross copies
If the black lines are showing only when you are using the adf. Clean the adf slip glass with windex< the small **** of glass to the left of the copy board glass.
Aug 04, 2010 | Sharp MX-2300N Color Copier
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
and parts purchased at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Streak in color printing only
Try this page from the Dell Community Support Forum. <a href="http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=26221&query.id=335768#M2622" target="_blank">Click Here</a>
Aug 22, 2008 | Dell 3010cn Laser Printer
Red streak poor color
If streaking is occurring only at the bottom of the page (i.e. the last area to print as the paper is fed beneath the print head), the problem may be due to improper curl of the paper. Many inkjet printers (Canon especially), rely on a slight curl of the paper so that it is "bowed" when it travels beneath the print head.
To see if this is the problem, gently roll a sheet of paper so that the print side is on the outside of the roll. When you place the paper in the feed area, it should have a very slight bow so that the center of the print side is slightly raised off the surface, while the edges are on the surface.
Also, make sure you use only OEM (Canon) cartridges. There is not a single "compatible" cartridge in the world that won't screw up your Canon print head. Take my word for it (and I DON'T work for Canon), you must use only Canon cartridges.
Dec 07, 2007 | Canon i850 InkJet Photo Printer
Xerox DOCUMATE 510 Flatbed Scanner Logo
247 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
