Question about Sony Computers & Internet
No Audio Output Device is installed
I just installed Windows 7
Everything works well, except for the sound..I don't have any sound!
Could somebody please help me with this issue?
    Sergeant:
  • 236 Answers
Plz follow this link, there is a window will be open , paset comments which is present there and download drivers for ur windows 7. i hopw u will get the solution.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Posted on Nov 17, 2009
No Audio Output Device Installed
might need to go in a do a system restore to a point before the upgarade
Dec 20, 2012 | HP Touchsmart 610-1030y 23" Lcd Desktop...
Don`t work on windows 7 crystal soundfusion(tm) Device : there is problem on windows 7 but run good on windows xp
This is a sound card that is no longer supported. Fortunately, sound cards are very inexpensive and easy to install.
Mar 29, 2011 | Crystal CS4280-CM Sound Card
I have a HP Compaq Presario V2000 notebook, I just upgraded to Windows 7 from XP and I now have no sound. It says "No Audio Output Device Installed" So I went to HP to download drivers, and it turns out...
mcdevito75 here, Hope I can help, From Start, click onto control board, the system devices, the speech and audio and make sure the sound is on. It"s possible the upgrade turned of your lap tops sound and has to be put back on.
Aug 28, 2010 | Computers & Internet
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
Jan 28, 2010 | ASUS P5GD2 Deluxe Motherboard
Audio driver instalation
Here is a list of things to try:
Note: Start with #s: 6, 7, and 9
1. Uninstall and reinstall the sound drivers
2. Install K-lite codec pack http://fileforum.betanews.com/detail...d/1094057842/2
3. Start > Programs > K-Lite Codec Pack > Configuration > Codec Tweak Tool and check the box next to [Registry] Fix non-working system sound
4. Make sure the volumes are not set to zero and that nothing is on mute Control Panel > Sounds and Audio Devices > under Device Volume, click on Advanced
5. Make sure that everything in Device Manager is fine (no yellow or red marks) Control Panel > System > Hardware tab > Device Manager
6. fixnoflashsound.reg (just click on the link and install it) http://files.filefront.com/fixnoflas.../fileinfo.html
7. netvol.reg (use Internet Explorer to click on the link and install it) http://www.kellys-korner-xp.com/regs_edits/netvol.reg
8. If possible, make sure Digital Output Only is not check marked (not all cards support Digital Output Only) http://tomebling.home.comcast.net/~t...oundConfig.jpg
9. Confirmed the presence of msacm32.drv and msacm32.dll
Search for these files in C:\Windows\System32
If you don’t have it, download it from here:
http://www.filesavr.com/msacm32
Made sure speakers are properly connected to sound card
Run SFC /Scannow
Start Menu > Run > type this in exactly (note the space between C and /): SFC /Scannow
Tried different Video player
Installed Quicktime Alternative
Reinstalled DirectX
Confirmed presence of "plug and play software device Enumerator"
Made sure that default devices were selected
Control Panel > Sounds and Audio Devices > Audio tab
Tried using different settings in the sound card’s configuration window
Installed Microsoft ADPCM Audio Codec and IMA ADPCM Audio Codec
for %x in (C:\WINDOWS\System32\*.dll) do regsvr32 /s %x
Thanks
Aug 09, 2009 | Intel D945GCNL Motherboard
No Audio Output Device is Installed
try installing a sound driver for it again
Feb 06, 2009 | Computers & Internet
"No Audio Output Device is installed"
I checked their website. Did you download the sound driver RAM2080 Win Vista x 86 15.02.2007 version 6.10.5337.0?
If so and it did not work it looks like you'll have to update the BIOS (BIOS update RAM2080 _only_ for MS Windows Vista 14.05.2007 version F0A. However BE VERY CAREFUL and follow the instructions EXACTLY, otherwise you may make the computer unbootable.
Jan 25, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
267 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
