Question about Sony KV-32S42 32" TV
Adding a audio jack to KV-32S42 sony TV
KV-32S42 tv dosnot have place you plug the head set. can jack be installed so i can plug the head set to the TV ?Best regqrd John
  • wpapas Nov 19, 2008
    i have a panasonic plasma tv and they tell me by plugging into the speaker wires like you said will not work now what?
If TV speakers are 100 watt and 60 ohm most of head sets are rated different. Do I have to add resistor parallel to head set to make them compatible?
Posted on Jan 10, 2008
Thanks for help
What I really need to know is that impedance deference between speaker of TV and impedance of head set. Is this going to damage the amplifier circuit of TV ? If impedance of speaker should be same as head set, how it can be done?
  • 579 Answers
Yes, just tap in at one of the speakers. The jack should have an internal switch so that the internal speaker is hooked up when the headphones are not in. Most TVs are now stereo (even though analog broadcast signals are mono) so may want to get a stereo jack and tie in from both speakers.
  • Anonymous Jan 11, 2008
    Headphones need virtually no power so it doesn't matter if they are
    impedance matched. TV audio power is pretty low anyway so usually
    doesn't overdrive the headphones anyway. Just turn down the
    volume if it does. But - put a resistor in series if you want it
    perfect.
6ya staff
SOURCE:
How can I turn the screen voltage up?
from description you are on the right track--screen con inside will either be on the crt circuit board or on the high voltage transformer, on or the other--lots of the older Sony sets when the picture tube gets weaker need this done.
Dec 15, 2012 | Sony KV-32S42 32" TV
Sony tv Kv-32s42 flashing stand by light non stop, sound but not picture
You probably took out the Horizontal Output. A repair like this is between 150-195 dollars.
Jun 06, 2011 | Sony KV-32S42 32" TV
Random close captioning shows up only disappears after turning tv off
Hi you can removed this by using your remote and access to your menu/close caption seting option and turn it off /or by using the menu button on the tv set
hope that help you.
Mar 21, 2010 | Sony KV-32S42 32" TV
Standby/Timer LED blinking
These unit are famous for the PCB Print to be cracked around the HV Circuit and or the Horizontal Drive Transformer pins needing to be resoldered. It can turn into a very Major repair if the HV Components short. In that case the Power Supply will also short out.
Hope this helps
Skyassoc
Jul 04, 2009 | Sony KV-32S42 32" TV
My tv blinks from regular picture to a black screen continuously.
your tv is on the blink.
remove the back panel of set
on the crt pcb board you will find a wite or black pot.
turn it up or down while set is on this is the [email protected] voltage ajustment.
you might get 3 monts to a year of extra life from your pictor tube by doing this.
regards,
daniel.
Dec 23, 2008 | Sony KV-32S42 32" TV
My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Nov 11, 2008 | Sony KV-32S42 32" TV
Fix my tv
please contact ur dealer
Mar 11, 2008 | Sony KV-32S42 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
