Question about Vulcan AUW230A Heater
I had a vulcan central heating unit that was made in 1990. Could you please tell me what the model number is on a 1990 vulcan central heating unit. Thanks, Rob
    President:
  • 1,515 Answers
Hi Rob, The number you have listed AUW230A may be the model number. You say its a central heat so, If it is a package unit, the model, serial, and all of the ratings would be on the unit near the elect box on a package unit.I do know by the # you gave me it is a Vulcan 3000 watt thermostatically controlled Immersion heater. Here is a link I can give you, they deal with this heater for parts Ect. that maybe of help to you, it is www.grainger.com. There are many model # and I believe this is it, AUW230A. I hope this helps Rob, Sincerely,
Shastalaker7
Posted on Nov 17, 2009
Bonaire Vulcan controller cct board 10 amp fuse keeps blowing
Obviously a direct short. Take pic, remove all wires, replace fuse. Wire by wire, turning power back on each time until fuse pops. When it does, there's your problem.
Jun 02, 2017 | Vulcan Heating & Cooling
Code error on central unit
1. Is this a computer monitor?
2. What is the code? They tell the problem in a shorthand way.
3. What is the model and what is the "central unit"? Is it a computer? Find a model number and ask again.
Apr 25, 2014 | Computers & Internet
How can i tell which vulcan 1500 i have?
The Vulcan year models range from the mid to late '80's to the anniversary model around 2006.
You can tell the year model from the 10th letter of the VIN
1980 = A
1981 = B
1982 = C
1983 = D
1984 = E
1985 = F
1986 = G
1987 = H
1988 = J
1989 = K
1990 = L
1991 = M
1992 = N
1993 = P
1994 = R
1995 = S
1996 = T
1997 = V
1998 = W
1999 = X
2000 = Y
2001 = 1
2002 = 2
2003 = 3
2004 = 4
2005 = 5
2006 = 6
2007 = 7
2008 = 8
2009 = 9
Mar 14, 2013 | kawasaki VN 1500 Vulcan Classic...
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
How can I check to see if my Maytag Air Unit still
If I am reading the serial number right it was made in the 16th week of 1990, and if I am right, there is no warranty.
You might have a partial year left on the heat exchanger on the furnace, but it is a prorated warranty on it, so even if it was bad, it would not pay much.
If I have helped please rate me, it helps being the new guy :)
Thank you and have a great day.
Paul
Apr 02, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Don't know how to start it
is the thermostat on? also there should be a master switch near the unit itself (with a red plate) make sure that is on (UP) also is it oil or gas fired?
Apr 18, 2009 | Heating & Cooling
10yr Vulcan Central Heating unit. Had tech come out and said main fan unit was faulty. I replaced myself and still not working. I discovered the O/Temp manual switch had cut off power. When I reset the...
I have the same problem, heating unit will not ignite, it trips out, i go into the roof cavity and remove the top of the unit (4 screws) and there is a motherboard, it has a Green light flashing what tells you the type of fault it has, mine has 3 Flashes telling me it a combustion air pressure system failure, ithen push the reset switch and it starts to initiate, a red light comes on and then it ignites and it will work for about 30 minutes to an hour and a half.
Hope this helps
Shane
Sep 08, 2008 | Heating & Cooling
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
Vulcan AUW230A Heater Logo
494 people viewed this question
Top Vulcan Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
blender719
Level 1 Expert
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
