Hi, I've got a GOODMANS GCR1875IP clock radio with Ipod dock and there is a constant buzzing coming from the unit. It sounds like others are having a similar problem when I searched the internet but is there anything that can be done to fix it,please?
  • dselvage Nov 17, 2009
    So it sounds like I'm still going to have to get a technician involved then. There's no way I can do the testing at home?
    Thank you for your help. You sound like you know what you're talking about!
  • 19,396 Answers
Hi.
You can get a similar problem on any audio equipment.
The buzzing noise on an audio circuit is caused by a grounding problem or by a defective component.
Test the radio on a different AC main.
If you still have the problem, then there is a faulty component.
In that case the unit must be taken apart and tested at component level by a technician.
If the clock is less than one year old, see if there is a phone number on manual, or call the retailer. This Items are supposed to have one year factory warranty and in that case the unit must be replaced.
Regards.
Posted on Nov 17, 2009
  • Ginko
    Ginko Nov 17, 2009
    Hi.
    You can do the testing yourself if you have technical training and experience on circuits.
    A basic training on electronics is about six months course.
    If you have training all you need is a multimeter and a capacitance meter.
    Testing is mainly done reading continuity (measuring impedance) to check if components or parts of the circuit have conductivity (circuit is not open).
    You set the multimeter to an appropriate Ohms scale, depending on the component you are testing.
    Testing will start from power cord earth. Read if it has continuity. The unit must already be taken apart to measure impedance from soldering on board.
    Then you test one or two resistors located directly on the ground AC circuit, before reaching the PSU big electrolytic capacitors.
    Then yo have a look to capacitors, if any looks bulged or leaking , then that is already faulty. Capacitors can only be tested using a capacitance meter.
    After that you locate putput lines from PSU (one on this unit), and control line from main circuit. You test resistors on output.
    A technician will also read volts out, that is quicker, but for a newbie it will be better not to work on hot wires.
    The only simple test that an untrained user can do is disconnecting the unit and testing it on a different main.
    moving power cod and gently whacking the unit to see if anything changes.
    If unit reacts positively to a whack test, then there is simply a broken contact inside. It will still require testing at component level and re-soldering.
    I do not like to suggest the whack test because if the user will put to much strenght , the unit may result damaged.
    Regards.
I have a Sony Dream Machine ICF-CS15iP Personal Docking Station. It won't play the iPod music through the speakers of the docking station.
I have the same radio and the exact same problem. I reset the radio and it wirks for a day. I go and try my iPhone the following day, and reverts back to error this device does..... Well you know the restored of resetting this thing every other day.
Sep 05, 2012 | Sony Dream Machine FMAM radio with...
I dont have the manuel for my proline clock ipod docking system
proline docking station model number crd1001 radio just working no sound nothing else comes on why
Aug 30, 2012 | Audio Players & Recorders
What features does the iPod/iPhone alarm clock have?
The Memorex iPod/iPhonealarm clock has the following features:
  • Dockingfeature for iPod/iPhone
  • iPod, radioor buzzer alarm settings
  • Sleep timer
  • FM radiowith preset stations
  • Batterybackup
  • Dimmerfunction
  • Line Jackfor connecting to other audio devices
Jul 23, 2012 | Memorex 02169 Ipod iphone Mini Alarm Clock
I have lost he instructions for my Ministry of Sound hi-fi with docking sysytem and don't know how to tune the dab radio...can anyone help?
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
May 31, 2009 | Sony STR-D600SS Shelf System
Instruction manual for innova docking station
They do not exist. I was not given instructions with mine. Now its only function is an Ipod charger and speaker.
Jan 30, 2009 | Innovative iPod Clock Radio with Dock...
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
Insignia clock radio goes to 12:00 after turning off power
I found this solution by reading some reviews. A reviewer said it was caused by a weak backup battery that powers the display. He said to change the lithium backup battery of the main unit with the backup battery in the remote. I tried it and now it works. I can turn the unit on and off and it doesn't reset my memory. But this hasn't solved my problem with setting the alarm.
Nov 23, 2008 | Insignia Digital Clock Radio with Apple...
ILive docking station not working properly
hello everyone with this problem I bought a use unit last sunday and it was working ok till next day then not sound not light , I try to push every botton and shut off and on but nothing , after many times I decide to open the boom box , and resoldering all the connections take like 1hour but now the unit works perfect the only thing is the blue light never came on , but cd works fine and radio also the dock for the ipod , is working fine
Aug 06, 2008 | Apple iLive IBCD3816DT Portable 2.1...
Buzzer instead of radio
I have this radio too and from what I have read in a review on amazon suggests alarm does not tune to DAB only FM - very annoying! Contacted Goodman customer care and they suggested it was a problem with a component but maybe it is just the design.
Mar 16, 2008 | Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
