Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Phomtom lines i have vertical lines see though lines moving from bottom to top in a never ending cycle is it broke or dirty? help please
  • ASCosgrove Mar 20, 2009
    I have the same problem. I've replaced two 3300uF caps on the power supply board, and two 1000uF caps on the board with the ribbon cables. However, my wavy vertical lines only show up on the component inputs. All three inputs to be exact. I know it's not a problem with the cable line because cable TV looks great. What is this LVDS? Please help. Thanks!
  • 24 Answers
It could be #1 a ground loop in the cable line....#2 bad caps in the power supply.....#Or a loose LVDS cable going to the light engine.
Posted on Jan 11, 2008
Thin yellow vertical line 8.5ins from left side of the 14.5 width,top to bottom of screen.Please tell me the problem.
Hi, this looks very much like a faulty TFT panel, replacing the screen will repair over 90% of this type of fault. Before going to this expense, does the line become intermittent if you move the screen forward and backwards? If so the screen connector cable routed through the hinges may be faulty. It is also worth taking the top off the machine and checking the screen connector is fully home on the motherboard and take the screen apart and check the same at the screen end. Please only attempt this repair if you are competent at this type of operation. A lot of other damage can be caused by breaking connectors etc if you don't know what you are doing!
Hope this helps
Olive Country Computers, Spain
Feb 14, 2011 | Computers & Internet
Dark horizontal line traveling across the screen vertically
on tube tvs bestto go on main bord look for hairline craks on soldering ok redo them nice it will light up happend to mine also older model thx nick
Feb 06, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Casio fx-9860G graphics calculater, vertical line segment
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
May 01, 2010 | Casio FX-9860G Graphic Calculator
How do you find the connection point for the horizontal rod that goes from the inside door handle to the vertical rod (with plastic knob at the top of it) that locks/unlocks the door? The car is a 1998...
The horizontal rod doesn't actually connect to the vertical rod. The horizontal rod connects to the door latch mechanism. The vertical rod also connects to the door latch, but at a different location. If as I'm guessing the horizontal rod has become dis-connected, it's probably because either the connector broke or fell off. If you need any further clarification, please leave a comment and I will try to help.
Jan 15, 2010 | 1998 Toyota Corolla
The screen on my toshiba 50h12 is messed up. its as though the horizontal is not matching can i fix this myself?
It sounds convergence out chips got bad in your Tv and causing problem. Replace convergence out ICs in TV if you are familiar with electronic stuff repair.
Required parts are available in Part Store.
Dec 24, 2009 | Toshiba 50H81 50" Rear Projection...
Vertical line top to bottom rightside of screen
hardware problem. please call manufacturer for warranty service
Nov 03, 2008 | Sony SDM-HS53/HT 15" Flat Panel LCD...
Vertical lines o my desktop
Sounds like your video inverter is bad or possibly the screen is going bad
Jul 21, 2008 | Toshiba Satellite M65 Notebook
Picture moving from top to bottom
you have a defect in the vertical circuit. most likely the vertical chip ,caps,diode and supply voltage for the chip..john
May 28, 2007 | Toshiba 57H81 57" Rear Projection...
Sceptre X20G Naga III showing horizontal and vertical lines
Yeah, there it... It's called a AD board. It that piece of component were you plugged your VGA or DVI cables to it. Panel scratchs repair kits, not recommended. Beside your panel could be already damaged by this problems you had. Replacing the AD board gonna cost you though...any where from $70.00 or more... My recommendation, just get a new one...saved you the headached and $$$.
Have a nice day!
May 02, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
