Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
How far from the shower head do recessed lights have to be fitted
How far from the shower head do recessed lights have to be? Our ceiling in the shower is quite low and the shower head comes almost up to the ceiling close to the lights. I can't seem to get an answer to this. Are they subject to building regs?
  • 5,603 Answers
552.54 Luminaires.
((B) Shower Luminaires. If a luminaire is provided over a bathtub or in a shower stall, it shall be of the enclosed and gasketed type and listed for the type of installation, and it shall be ground-fault circuit-interrupter protected.
The switch for shower luminaires and exhaust fans, located over a tub or in a shower stall, shall be located outside the tub or shower space.
Essentially there is no distance specified BUT the fixture must be sealed AND protected with a GFCI
Posted on Nov 17, 2009
Ceiling mounted shower head (Danze) leaks water for a good 30-40 seconds long after being turned off
you really can not because of the overhead piping holds lots of water and so does this big head....that is just normal for these things...i am a licensed plumber for over 34 years and have done these...its just draining out all the overhead water....
Oct 06, 2012 | Danze Home
Hello, I am putting in a grohe 35016 rough in valve. My shower has cold/hot 1/2" pex line coming in and i need to have one line going up into the ceiling for a rain shower head and another line going...
Hook the cold line up to right side and hot to left. Run line to wall shower off the top and use two 90 degree elbows with a short length of pipe turned slightly to the side of the line to wall shower. Run pipe up to ceiling height then 90 over and down to location you want forrain shower head. Hope I made this clear as I know sometimes I don't explain things well. Thank you.
Feb 04, 2011 | Home
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
How to dissassemble shower head
The shower head is removable with a crescent wrench and a pair of pliers, or two pair of pliers. Put electric tape where pliers will grasp to avoid scratching. The shower head is attached to the extension pipe like a regular screw on fitting, so to loosen turn counter clockwise. As far as disassembling the head itself, some are meant to come apart, others not. Use white tefllon plumbing tape to re-install.
Please rate this answer for me. Thank you.
Mar 25, 2010 | Moen & One Handle Tub & Shower Faucet
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Leak in the shower is leaking water through the ceiling
SInce it is wet both under and behind the shower I would rule out the drain floor pan and drain system and think it most likely to be the pipe leaking from the mixing faucets to the shower head. Find studs directly behind shower faucet, n each side. Locate the center of the studs and put vertical lines up and down on the center line of the two studs closes to but outside the shower  faucet on each side. Approximate 6 inches or so  up and down for the height of the shower faucet (Valve, not head) Put Horizontal lines across between the two line at both the top and the bottom/ You now have a square.Using a Razor knife(Sometimes called a box knife, stanley 99a for example) cut into the lines of the square back and forth as deep as you can. Cut an x  acrossthe square corner to corner again as deep as you can . Lightly hit the center of the x until the drywall caves in . Cut the remaining drywall out for the square. Now while  the shower is running you will be able to see whee the leak is. Use pipe seal after disassembling the loose fiting or repair the leak iun what ever manner is necessary. Replace and repair the hole made in the drywall  with another piece of drywall, tape and joint cement. .
Feb 27, 2009 | Home
The weight of the arm and rain head is too heavy for fixing
can you at all shorten the length of the arm to make the head lighter or can you do the adjustment near the tiles up tighter apart from this attach unsightly bracket from the head back to the wall at worst mate start pulling tiles off ouch ! wish i could more help glenn..
Nov 20, 2008 | Grohe 27.217.EN0 Rainshower 6" Ceiling...
Fitting Electrical Shower -electrician will do final connection at consumer unit
Sorry,
Thought the service was free
Silly me, only found out it wasnot after I had typed the questioin and thought it would then be aired on the forum anyway
Thanks anyway,
Roger
Jul 31, 2008 | Kitchen Appliances - Others
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
318 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
