Question about Intermatic T104 24h 208-277v Mechanical Time Switch
Ckt diagram canacation diagram
  • 565 Answers
For anyone else who may reading this post, please note that this diagram is for the T104 ONLY.
Here ya go: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Basically, connect the incoming (line) 240 volt wires to terminals 1 and 3 and the outgoing (load) wires to terminals 2 and 4. Of course, connect the (bare or green) equipment ground wires from both cables to the "GR" terminal.
Posted on Nov 21, 2009
99 Corvette Headlights open and close for no reason When I'm driving down the road they will just pop up and a little while later close. Then I hear what might be a motor, Any suggestions? Thanks, Don
Could be the switch going bad or a short in a wire. If it had ever been in a accident that is where i would look for a broken or smashed wire.
Sep 30, 2017 | Cars & Trucks
Which fuse is for the brake lights on a 2000 olds bravada? how is it labeled?
During stoplamp operation, power is supplied from the STOP LP fuse in the underhood fuse block through CKT 1540 (ORN) to the TCC/stop lamp switch. When the brake is depressed, the contacts of the TCC/stop lamp switch close, routing power to CKT 17 (WHT). CKT 17 supplies power to both the VECHMSL fuse and the stop switch contact of the hazard switch. From the VECHMSL fuse, current flows through CKT 1320 (LT BLU) to the high mount stoplamp and high mount stoplamp resistor. The ground is provided by G450 through CKT 1350 (BLK). From the stop switch contacts of the hazard switch, current flows through the turn signal switch to CKT 1418 (YEL/BLK) and CKT 1419 (DK GRN/WHT). CKT 1418 (YEL/BLK) supplies power to the LT TRN (rear) fuse (which feeds the LH rear park and turn signal lamp terminal A) through CKT 618 (YEL). Ground is provided by CKT 1350 (BLK) to G450. CKT 1419 (GRN/WHT) supplies power to the RT TRN (rear) fuse (which feeds the RH rear park and turn signal lamp terminal A) through CKT 619 (DK GRN). Ground is provided by CKT 1350 (BLK) to G450. When the left or right turn signal is turned ON, the appropriate turn signal will flash. The opposite side will remain ON in order to serve as a stoplamp when the brakes are applied.
Sep 29, 2017 | 2000 Oldsmobile Bravada
My 1998 cad. seville sls reads check underbody , do not exceed 90 mpr, what could be wrong ?
SPEED LIMITED TO 90 MPH -- 113
When the RTD detects that a suspension related malfunction desist and the PCM has received a class 2 message to limit vehicle speed. The PCM sends a class 2 serial data message to the IPC requesting that this message is displayed.
RTD
Real Time Damping
Your best bet , take it to the cadillac dealer
DTC C1326 Battery Out of Range
DTC C1650 RSS Control Module Fault
DTC C1658 RSS Control Module Calibration Fault
DTC C1710 LF Damper Actuator Short CKT to Battery
DTC C1711 LF Damper Actuator Short CKT to Ground
DTC C1712 LF Damper Actuator Open CKT
DTC C1715 RF Damper Actuator Short CKT to Battery
DTC C1716 RF Damper Actuator Short CKT to Ground
DTC C1717 RF Damper Actuator Open CKT
DTC C1720 LR Damper Actuator Short CKT to Battery
DTC C1721 LR Damper Actuator Short CKT to Ground
DTC C1722 LR Damper Actuator Open CKT
DTC C1725 RR Damper Actuator Short CKT to Battery
DTC C1726 RR Damper Actuator Short CKT to Ground
DTC C1727 RR Damper Actuator Open CKT
Aug 10, 2017 | Cars & Trucks
Saui TVM1316 full ckt diagram
Check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Circuit diagrams are in PDF. Cannot include it here by this windwow.
Jul 15, 2014 | Sansui TVM1316 13" TV
What are the following Code definitions on a 1996 Ford Contour: 157, 158, 159, 181, 327, 332
157= 02 sensor ckt low volts 2/ 2 158=o2 sensot ckt high volts 2/ 2 159= o2s ckt slow response 2/2 181= fuel temp sensor a ckt rng/perform 327= knock sensor 1 ckt low imput bank 1 or single sensor 332= knock sensor 2 ckt low input bank 2
Jul 19, 2011 | 1996 Ford Contour
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
457 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
