Question about Brother MFC-5840CN All-In-One InkJet Printer
Print function stopped working. Brother MFC 5840CN
I downloaded an update for Print Shop Pro program. My Brother MFC 5840CN just stopped printing.
Brother MFC 5840CN will not print. I get the error message : Unable to Init. See Troubleshooting and routine maintenance chapters in User's Guide. I followed the instructions and got nowhere.
I uninstalled all MFC 5840CN software. I also downloaded uninstall Brother software and the full Brother MFC 5840CN software package.
I couldn't find anything on the Brother website about the printer function not working. A lot of information about setting up and using the FAX function.
I don't want to FAX. I just want to print and copy.
The paper feed works, the fax function dials a number, with sound.
The ink cartridges are in place, there's nothing stuck in the printer.
What's wrong with my MFC 5840CN? How do I fix it?
  • 6 more comments
  • doug4kner May 08, 2008
    Printer wont connect to pc tried ever thing
  • Jazzy20743 May 12, 2008
    Thanks for your response.
    I contacted customer service at Brother.com. The problem was due to mechanical failure. The authorized service center quoted me a price of about $150 to fix the printer. I trashed the original printer and bought another for $49.00.
  • Anonymous Mar 12, 2014
    blurred print
    Brother MFC-5840CN All-In-One InkJet Printer, blurred print related issues
    blurred print
  • Anonymous Mar 13, 2014
    how to power purge
  • Anonymous Mar 21, 2014
    When printing in color, red come out brown
  • Anonymous Mar 24, 2014
    How do I get the Fax as pdf menu when printing?
  • 832 Answers
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Posted on Jan 10, 2008
6ya staff
SOURCE:
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
The black will not print. I have replaced the cartridge with two new ones. Color prints ok. Brother mfc 5840cn
please perform head cleaning to see if there is any ink out.. goto ink management and select head cleaning... after that goto ink management and print the nozzle check.. see if there is any black ink out...if no ink out..then more probably your print head is badly clogged..and you will need to get it replaced.
Jun 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Oct 28, 2009 | Brother MFC-5840CN All-In-One InkJet...
Ink Cartridges are full but keeps telling me they are not to then
as a printer mechanic .i had got many customers coming at my work shop with this problem .and it gets soved by replacing the cartridge with new cartridge.as you said cartridges are full still it says change cartridges.but if the circuit of the cartridge is got faulty it will not print let it be full.so clean the brown colour metal circuit on the cartridge with a dry tissue.if its due to dust got stuck up on the circuit it will print otherwise the cartridge has to be changed in this case.
Feb 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC 5840CN - no print
you need to go to brother.com for the solution
Jan 08, 2009 | Brother MFC-5840CN All-In-One InkJet...
Out of memory
you need to clean out the units memory
Print data remains in the MFC’s memory
Re-start printing from your computer.
Print data remains in the MFC’s memory. The USB cable was unplugged while he computer was sending the data to the MFC.
Press Stop/Exit. The MFC will cancel the job and eject the page that is being printed.
Aug 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN Unable to clean
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Apr 25, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to print message on Printer LCD
The print head is defective and needs replacement.
BTW the sparepart costs quite a lot of money.
Its better to buy a new mfc!
Sorry!
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
808 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
