Question about Epson Workforce 30 Laser Printer
Driver won't uninstall.I plugged in the USB cord too soon and selected what I thought was the right port via Manuel option. I now know I am supposed to plug in the printer mid way through the installation process and can't uninstall the drivers so I can do it right.
ohms
  • 1879 Answers
SOURCE: USB plug in Epson Printer RX595
assuming you properly installed the "printer driver".
disconnect the printer.
check Printer & Faxes for printer icon(s) - delete print queue(s) and the printer icon(s).
open device manager and go to Universal Serial Bus Controllers section.
now we check for connectivity: (treat the printer and scanner as separate devices)
connect the printer, USB Printing support must show up (also check Imaging Devices and the scanner must also show up)
IF USB Printing support shows, windows will create a printer icon in the Printers & Faxes, right click choose properties and print a test page.
ELSE, it's the printer and request for a replacement if it is still within 1 year from the date of purchase
Posted on Feb 26, 2009
gwbm
  • 353 Answers
SOURCE: Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Posted on Feb 28, 2009
SOURCE: CX8300 printer driver cant install
update your windows installer ... v3.1 and uninstall everything related to your printer e.g. drivers, any software, disable the unit in hardware devices (control panel) download the latest driver directly from Epson
Posted on May 07, 2009
SOURCE: Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Posted on Dec 13, 2009
Trying to add a printer to computer via usb 2.0 printer cable
plug your printer into any usb input point on your computer
found new hardware wizard should start or you might have to do it manually
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Feb 14, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Dane-elec usb portable memory does not appear when plugged into my usb port
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 10, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My computer wont recognize the USB cord
make sure the lead is securely seated into the usb port and that its not bad/faulty
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 23, 2011 | Computers & Internet
I plugged my usb stick into my computer. It recognises something is in the port but asks me to insert me stick when I double click on the usb stick folder in my computer
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
hope this helps
Jan 22, 2011 | Computers & Internet
I purchased a flash drive/key. I can not find an open port for which this key fits into. Why?
im not sute what you mean you cant find where to plug your flash drive into just plug it into a USB port or maybe your computer does not have a usb port
hope this helps
Jan 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Don't know if it is the motherboard or not. Computer will not recognize USB ports (rather things plugged into them), Added another board just with USB's. Didn't work. Someone suggested that a BIOS...
hope this helps
Jan 16, 2011 | ASUS P4B533 Motherboard
Usb ports not recognised
Right click on the yellow flag and uninstall the corrupt driver. Restart the computer, plug a USB device in and it should be resolved. If not post back.
Regards.
Jun 29, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Dell 942 cant communicate. cords are ok. tried but am not computer savy. please help with a simple solution. yellow Excamation point on the printer icon. recently put on trend micro and peer guardian....
For that you need to uninstall printer and usv driver .
You can uninstall those in device manager.
Right click on my computer icon then click on property.
Then hardware->device manager.
Then uninstall all usb drivers 1 by 1 .
Then uninstall printer driver.
USB driver are installed automatic.
For your printer download driver from below link.
click here
click on above link and select your operating system then download driver then install.
Then check.
Also connect usb cord of printer to defferent usb ports on computer.
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Dell 924 All-in-One InkJet Printer
USB's won't work on emachine T1842
hi.. even i too had the same problem.. The solution is in device manager if u select USB option u will be able to see 6 USB sub options popping down from the menu... select each option and right click it... u can see the option uninstall.. try to uninstall all the 6 ports in that device manager.. after clciking uninstall option shut down ur system and restart it again.. now ur USB ports are ready to work...
Feb 09, 2009 | E-Machines T1842 PC Desktop
HP Photosmart C4180 won't print
hello
you can get the newest vista software for your laptop from
CLICK HERE
Apr 28, 2008 | HP Photosmart C4180 All-In-One InkJet...
Epson Workforce 30 Laser Printer Logo
134 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
