Question about Zenith XBS344 System
I need to install a deutsch akustik d-85 surround sound system but do not have a manual
Panasonic SA-PT467 I am trying to find the original description of my DVD home theatre system. I cannot find anything about it!!
Manual and Review
Panasonic SC-PT467 Manuals
https://www.manualslib.com > Brands > PANASONIC Manuals > Home Theater System
  1. Cached
Manuals and User Guides for PANASONIC SC-PT467. We have 1 PANASONIC SC-PT467 manual available for free PDF download: Operating Instructions ...
Panasonic SC-PT467 Home Theater System ' Product overview ' What ...
www.whathifi.com > Products > All-in-one-systems > Surround systems
  1. Cached
  2. Similar
Panasonic SC-PT467 Home Theater System overview from the experts at What Hi-Fi? - compare latest prices, see user reviews, and see specs and features.
Panasonic SC-PT467 5.1 Surround Sound reviews, prices and deals ...
https://www.reevoo.com > ... > Sound channels : 5.1 surround sound > Panasonic
  1. Cached
  2. Similar
Rating: 8.4/10 - ‎33 votes - ‎Price range: Compare prices Latest Panasonic SC-PT467 reviews, ratings from genuine shoppers. Find best deals and buying advice from consumers on Panasonic SC-PT467 from Reevoo. Surround sound effect‎: ‎8.8 Clarity of instruction manual‎: ‎6.9 Sound quality‎: ‎8.4 Panasonic SA PT467 Google Search
Dec 05, 2016 | Panasonic Audio Players & Recorders
Need manual please for Theater Research TR-502 5.1 Surround Sound
Good day. The best I can do for you is a link where you must request the manual online. Go here http://www.audiocircuit.com/Home-Audio/Theater-Research/TR-502#manuals. Hope this helps!
Jul 07, 2010 | Theater Research TR-502 5.1 Surround Sound...
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
The operating system of my toshiba laptop is in deutsch.
You cannot convert a Deutsch version to an English version. You will have to reload the operating system to accomplish that.
Mar 16, 2009 | Toshiba Satellite A100-S8111TD Notebook
Surround sound problems
you need an optical cable which it's sort of mentioned in the manual, but because of the multitude of possible ways to connect the TV to the sound surround, I did not figure out either.
I got my optical cable at BestBuy for about $45.00
Jan 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
On board sound
Hi nrls14, it can get pretty confusing with Gigabyte.
Go to page 9 in your manual or Pg 13 if using Adobe Reader. Motherboard layout. If you download the manual which is in pdf format you'll be able to enlarge the manual which will help you to see everything much better.
Download manual from here: http://china.giga-byte.com/FileList/Manual/motherboard_manual_7n400pro2_e.pdf
This is the English manual. (Downloading from china is a faster site).
Find SUR_CEN located between PCI slots 2 & 3 on the motherboard. Than go to pg 32 in manual or pg 36 in pdf. Set the pins SUR_CEN. Set a jumper over pins 1&2 & 5&6.
Front Audio Connector, leave a jumper across pin 5&6 & 9&10 (Default). On page 22 in manual, pg 26 pdf. Follow Method1:
Instructions. (Test your speaker system). You may need some tweaking & this can be done with the software included on the Gigabyte CD by installing the sound effects manager. Go to page 78 in your manual or pg 82 in pdf. Page 80 in manual, pg 84 in pdf. For six channel 5.1 sound. If you decide to use the Advanced 6 Channel Analog Audio Output Mode (using Audio Combo Kit, Optional Device). Follow the instructions on page 81 in manual or pg 85 in pdf. (Do not let the picture on pg 81 spook you). Pg 81 shows a set of pins not located in-between the two PCI slots. You make this connection by removing the two jumpers on SUR_CEN & plug in the SURROUND-KIT on to SUR_CEN pins. Lastly, both motherboard manuals are the same for the GA-7N400 & the GA-7N400 Pro.
Good luck nrls14!
Mike
Aug 25, 2008 | Gigabyte GA-7N400 Pro Motherboard
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
Zenith XBS344 System Logo
751 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
