Question about Labtec 961307-0914 Webcam
I m connected yahoo messenger while i m open cam that time give a massege 'a network error occurred while connection to the server '
  • 621 Answers
In messenger in the main window goto Messenger / Preferences then Video & Voice. Make sure in the drop down box your camera is listed and also make sure the box in same window which says "allow USB devices to access messenger" is ticked. If still no luck test your camera on another application such as MSN or Skype. Cheers from Scott............might catch ya on yahoo sometime
Posted on Dec 12, 2009
    Genius:
  • 3,422 Answers
HI,
This type of issue is usually solved by reinstalling the particular software which is giving the network error.
Please reinstall the yahoo messenger and let me know if you still face the same problem or not.
Thank you for using fixya.
Posted on Nov 17, 2009
When i am trying to login in my yahoo messanger. it opens a window of troubleshooter when i clicked on it. it shows the checking the virtual ip servers .. after that it shows the...
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Dec 12, 2010 | Yahoo Messenger
Your computer is not connected to the network when cam talk
In order to use the video call feature both parties have to be in Yahoo Messenger 10.
If you both have Yahoo you can use the webcam
If you are cross chatting - eg Messenger X MSN, only basic IM will be available
Jan 12, 2010 | Yahoo Messenger
I cant view and friends cant view my web cam while
1. check your internet connection
2. if there is nothing wrong, try to download and install a newer version of Yahoo Messenger
Oct 10, 2009 | HP Pavilion dv6000z Notebook
Hi, my friend is trying to view my webcam...but she is getting an error message saying "a network error occured while connecting to the server"
thats a generic problem with yahoo messenger when the server is bussy it gives this error. If your friend is using dial up this is the biggest prob. She will have to get a faster connection. Meanwhile I'd suggest her to download the latest version 9.0.0.2162
Kindly rate my solution.
Jun 29, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
I m not able to open my yahoo messanger......
There are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Jun 10, 2009 | Yahoo Messenger
Connection problem 81003004
To solve this kind of network connection in your yahoo messenger, just click on your yahoo messenger, select the connection preferences in the menu and then select the proxy server as the connection preference other than the internet one. then select from either the dial-up, broadband or the high speed t1 lan connection. it's up to you how you connect.
it works for me. hope this can help you.
cheers,
argion
Jan 19, 2009 | Microsoft Windows XP Professional
Error message connecting web cam on yahoo messenger
make sure that the web cam attached to the personal computer nor
in remote computer . if it attached to the remote computer it may have permission problems.
Dec 13, 2007 | Logitech Webcam
Webcam connecting to server error
there as bin sever problems with yahoo this wont be down to the cam keep tryin the cam an yahoo should sort it out in tym
Nov 17, 2007 | GE EasyCam Plus Webcam
Labtec 961307-0914 Webcam Logo
107 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
