Question about Acer Aspire 3100-1405 Notebook
I did a system restore from the disks. Everything
I did a system restore from the disks(system and recovery). It took approximately 10 tries before I finally got the disks to complete recovery. Everything seemed to be successful. However, on restart the laptop lets me choose to start normally or last good configuration, etc. when I choose it shuts off. It is an acer aspire 3100-1868. I have tried to start in safe mode without success.
    Sergeant:
  • 267 Answers
You will need to reload the window NTLoader is not reading your masterboot record. reinstall windows again make sure the disk is clean .
Posted on Nov 17, 2009
New acer says password incorrect
Try a system recovery, if it has a recovery partition. Remove any madia,DVD, CD, USB, etc. Unplug, remove battery, plug in, push the on/off button, immediately prees and hold the ALT+F-10 if that doesn't work, reboot and use F-10, to load the restore/recovery software, do a factory recovery to return to factory settings. You may want to write down the password and put in a safe location, or put your user name with a administartor password to override.
Dec 25, 2012 | Computers & Internet
Acer travelmate 4202 recovery disc
You can, if available, purchase a Recovery disk from Acer. That said, if you have a Recovery Partition, By rebooting and using the restore/recovery ALT+ F-10 keys. On page 59 : http://support.acer.com/acerpanam/manuals/acer/0000/userguides/TM4200-ENG-OLM_1207.pdf and this may be useful: http://support.acer.com/us/en/product/default.aspx?tab=2&modelId=774 IF you are doing a Factory recovery on a XP Machine, I would put on a pot of coffee. I recently did the same, with hundreds of Windows and Computer manufacturer's update it took 36 hours stright. Good Luck.
Dec 23, 2012 | Acer TravelMate 4230 Notebook
When trying to use system disk unable to choose a restoration option
If you are doing a system recovery from disks you created or purchased most times they don't work. You might as well reinstall the operating system.
Have you tried doing a System Restore? System Restore will allow you to select a Restore Point (date and time) when your system was working ok. System Restore does not delete your data, documents, music, pictures, videos or programs unless the program was installed after the restore point you selected.
System Recovery or Factory Restore deletes everything.
May 30, 2012 | Computers & Internet
Averatec 7100 laptop factory recovery disc
Most times the recovery discs don't work. Why not just get an operating system disk and reinstall the operating system?
Have you tried doing a System Restore? System Restore will let you select a Restore Point (date and time) before you started having problems. System Restore will not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected). System Recovery on the other hand will delete everything and set your system back to the point when you first purchased it.
To start System Restore click Start/Programs or Start/All Programs. Click Accessories/System Tools/System Restore. When it opens you will have the option to select another restore point (date and time) than the one shown.
May 22, 2012 | Computers & Internet
Hi there , how do i completly reset my Acer Aspire E380 desktop computer to factory settings again . i have backed up everything i need and i just want to start again completely and wipe it all. any...
Hi.
With that desktop computer being new it should have a hidden recovery partition on the hard drive that allows you to perform a factory restore which will take it to how it was when you took it out the box.
To access the recovery partition on your Acer computer for recovery, follow the steps listed below.
1. Power on the computer
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery.
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image which should take approximately 10 minutes.
6. Once eRecovery has run, press OK to reboot the computer.
Hope this helps!!!
Regards.
May 31, 2011 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
How do i restore my computer back to the way it was when i bought it?
You will need to format the hardrive. This means you will be erasing EVERYTHING on the hardrive. Before you do this though, you will want to make sure that you have the restore disk and system disk which should have come with your computer. If you don't have these disks do not attempt this, you will end up with just a big paper weight.
Have you tried using the "restore" option in accessories? This will restore your computer back to an ealier checkpoint without losing the operating system and drivers. I would try this first.
Hope this helps
Feb 22, 2011 | Compaq Presario CQ60-220US PC Laptop
Does any one have gateway GT5220 Installation disk ?
Create an ASR Floppy Disk loadTOCNode(2, 'summary'); The following steps can create an ASR floppy disk from an ASR backup operation: 1. Format a 1.44 megabyte (MB) floppy disk and insert the disk into the floppy disk drive of the computer. 2. In System Tools, start the Backup program. When the Backup and Restore Wizard is displayed, click Next. 3. Click Restore Files and Settings, and then click Next. 4. In the What to Restore dialog box, select the media that contains the ASR backup. Ensure that the media is inserted. 5. Expand the Automated System Recovery Backup Set that corresponds to the ASR floppy disk that you want to create. 6. Expand the second instance of the drive letter that contains the system files. Expand the Windows_folder/Repair folder. 7. Click the following files from this repair folder: Asr.sif and Asrpnp.sif, and then click Next. 8. At the Completing Backup or Restore Wizard screen, click Advanced. 9. At the Where to Restore screen, set the Restore Files to: dialog box to Single Folder, and then set the Folder Name dialog box to the root of your floppy drive, for example, "A:\". 10. Click Next. The other options in this wizard are optional and do not affect the transfer of files to the floppy disk. When the wizard is finished, the files are copied to the location that you had previously specified. The ASR floppy disk is ready for use in the event of an ASR restore operation.
NOTE: The Asr.sif and Asrpnp.sif files must reside on the root of the floppy disk drive to be used during a ASR restore operation. Starting the Windows Recovery Console loadTOCNode(2, 'moreinformation'); To start the Windows Recovery Console, use one of the following methods: • Use the Windows Setup floppy disks or the Windows CD-ROM to start your computer. At the "Welcome to Setup" screen, press F10 or press 'R" to repair. After you start the Windows Recovery Console, you receive the following message: Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to exit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log on to
(To cancel, press ENTER)? After you enter the number for the appropriate Windows installation, Windows will then prompt you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot have correct authentication. After you enter your password and the Windows Recovery Console starts, type exit to restart the computer.
When you use Windows XP Professional, you can set group policies to enable automatic administrative logon.
Use the Winnt32.exe utility with the /cmdcons option to add the Windows Recovery Console to the Windows Startup folder. This procedure requires approximately 7 megabytes (MB) of hard disk space on the system partition to hold the Cmdcons folder and files.
Aug 02, 2008 | Gateway GT5220 PC Desktop
I need a recovery disk for a advent 5401 do you know where to get one
Recovery disks are created by the os system U R using, before U crash. Normally there are no recovery disks because everyone sets up there system a little different. U R supposed to create a Rdisk after U have everything where and how U want it and it is operating good.
Jun 13, 2008 | Computers & Internet
Restoration disk
Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
1. Plug in the AC adapter.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4. A screen stating "Starting Acer Erecovery" should appear.
(Release ALT and stop tapping F10 at this point)
5. There will be 4 options:
1. Restore system to factory default
2. Restore system from user backup
3. Restore system from cd/dvd
4. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
1. If recovery cd/dvd's were created, they can be used to restore the system.
2. Insert disc 1 and follow the prompts.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 3100-1405 Notebook Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
