Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Phantom horizontal upward-scrolling lines... from a PS3 with HDMI to DVI
I have had a Panasonic PT-47WX53 rear projection HDTV for about four years now, and all has seemed fine up until this past week when I got a PS3 for Christmas. I only have DVI for a digital input on the TV. I had bought a $100 DVI-to-DVI cable about a year or so ago, to use with a Hi-Def cable-box at the time. However, my cable-service provider told me that they had not enabled the use of that output on their boxes, but I kept the cable anyhow in the hopes that that would change. It didn't.
Anyhow, somewhere in between then and now I also picked up a $20 DVI to HDMI adapter end for my expensive cable, to update it (as everything is now all HDMI, including the PS3) so I wouldn't simply LOSE the hundred bucks I had invested in it.
So when I got the PS3 last week, I set all the settings on both it and the TV (correctly, because I get picture and sound) for using the digital DVI cable with the HDMI adapter.
The problem is, after trying out a few Blu-Ray movies, I noticed a few horizontal "ghost" bars scrolling up my screen. They are not as noticeable when there is a bright image pictured on the screen (which is probably why I did not see them at first) but whenever the screen is predominantly darker, these bars are obnoxiously present. I checked some of the other inputs on the TV (antenna, component, etc.) and I DO notice a similar but far more faint image that I would almost never have seen if I had not been looking for it.
My question is threefold:
1. Is this a form of electromagnetic interference?
2. If not, then what is it?
and
3. How do I fix it (cuz it's bugging the crap out of me)?
i have a mitsu 53-2 inch rear projection hdtv and i have had it for three years and i had noticed the other day the exact same thing you were describing i came online to see what i could find and here it is not the answer but the problem i dont think it has to do with the ps3 but i wonder what it from and how to fix it it is driving me crazy i did have the dvi hooked up but not anymore help please
  • Anonymous Nov 05, 2008
    Ditto here.  I have the exact same HDMI to DVI set up as you.  I recently heard it was a grounding issue with the PS3 power supply.  I'll try that soon and get back to you!
  • 24 Answers
Everything works better on component, I know the salesman at the store says its better, but its not....I tell customers all the time (I could hook up three tvs side by side..HDMI-DVI-Component and the human eye cannot tell the difference) The reason the DVI and Hdmi were created was for copy guard encription....Although the component is an analog signal, it goes to a A/D conversion..........But this is just my insane opinion...Good Luck
Posted on Jan 11, 2008
PT-47WX53 power light blinks five times
Five blinks means short on the 140 volt line inside the set. How much skill do you have? You will need a Ohm meter----to check for a short.
Clearly I do not know what skill or expertise you have---You tell me and I will tell you depending on your answer where to and how to check for a short---The 140 volt line feeds the Horizontal output circuit.
Most likely you have a short to ground there.
let me know and I will try to assist you.
SD TECH
Jan 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX53 47 in. Rear Projection HDTV Television
replace the DG board which is the small board which plugs into the A Board ( on the left side looking in rear of the set) The DG is the board which lays flat on top of the A board. You can get the A board and the DG board combined at www.tvrepairworld.com They may sell it seperately if you inquire.
Dec 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
No picture
Petty vauge possible Flyback/horizontal. since you don't get codes.. I would start with checking for +210 at D519, or look for high voltage.
Oct 04, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
i just unplug my cable line when playing my ps3 and the lines go away
Jan 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Oct 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 Horizontal Picture Size
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable or satelite receiver box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 28, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
325 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
