Question about LG VX8550 Cellular Phone
I have a LG VX8550 (Chocolate 2). I have a USB cable for it, and a Micro SD card that I can connect to my computer. I have found a site to download games for it, both the jar and the jad files. And I have transferred the files over to my memory card, but I cannot figure out how to install it. How do I install it? And do I have to make a folder on my SD card named something specific to put the game in, or can I just put the game files anywhere on the card?
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
Can't download songs from Rhapsody to my new LG Chocolate
I can help you with the computer problem. I assume that you're using USB cable to connect your phone to your computer, so you need a driver. Download it here: http://content2.ztango.com.edgesuite.net/VZW/MEM/VZMM2-DL-LG-Bld39-81k-83k-85k-8550-86k-87k-94k-98k-99k-002.exe After you download it, install it, and then try to plug in the phone to the computer by the USB cable. If you need further help, chat live with me or something. Good luck.
Jul 13, 2007 | LG CHOCOLATE VX8500 Cellular Phone
How do I get games onto my LG-VX8550 (Chocolate 2)?
if your phone is a JAVA applicaion supporter then try with jar
Jun 02, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Download photos from phone to PC
well check if it has a micro sd card or usb data transfer cable if not you can try sending through a text to your email adress hope this helps
Jun 01, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Try using a usb card reader.. just put your sd card in appropriate card reader. and insert that card reader in your pc transfer your file in your sd card.. and install in your mobile..
have fun
May 19, 2009 | LG VX8550 Cellular Phone
Easy: visit http://www,getjar.com
Select your phone type and model number and you will have millions of games and utilities to download for free. Download to your computer then transfer to your phone.
rate this fixya
Apr 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
How do you put music into a LG Chocolate 8550
Hi Eman,
Plug in you r phone with your USB to your PC and then Go to MY Computer and see the drive letter where your LG phone connect (removable disk), click there and see the sub folders inside and you will see a folder named MUSIC, here where you can save the mp3 (music) you wanted for your phone.
Hope it helps.
Enjoy.
Pls. rate & hope to hear more from you soon.
tnx
-micro
Feb 10, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Adding music to my phone
DO YOU HAVE A MICRO SD CARD? IF U DO PUT IT IN THE PHONE AND USE THE USB CORD TO TRANFER MUSIC USING WMP11 AND SYNC UR MUSIC TO THE DEVICE BUT ALWAYS REFRESH THE DEVICE MAKE SURE U FORMAT THE MEMORY CARD IN THE PHONE KEEP TRYING IT WILL WORK IT DID FOR ME.
Feb 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:http://www.mptrim.com/
  2. To set it as a ringtone, send it as an attachments to you areacodeandyourphonenumber@vzwpix.com. It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Jan 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG VX8550 Cellular Phone Logo
135 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
