Question about Garden
Instructions needed on how to thread line into spool on a new ryobi touch start trimmer
SOURCE: Jammed line spool on Ryobi gas trimmer
On my Ryobi trimmer, all I have to do is unscrew the knob (the device that you "bump" to advance the line) at the bottom of the spool and the spool can be lifted out. I had to use a strap wrench the first time since it was on very tight. You don't have to line up any arrows to remove the reel.
Posted on Sep 24, 2008
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
rycgl
  • 1545 Answers
SOURCE: I need to see the parts to a trimmer spool for
Unfamiliar with this model. More info would help or you can check on the manufacturer's web site?
Posted on Aug 07, 2010
vincob
  • 718 Answers
SOURCE: ryobi rht2660da hedge trimmer starts
If it brand new take it back to where you bought it, it's probably still under warranty. Why try to fix something you don't need to???
Posted on Aug 30, 2010
How to attatch trimmer line to RYOBI ELT400
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, hdy
Jan 30, 2012 | Ryobi Garden
How do you replace the cutting line
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 11, 2012 | Ryobi Garden
I have a ryobi RWT285DS and the head is not releasing the whire evenly, upon closer inspestion i found the part that the wire is wrapped around is sitting loose. what part am i missing?
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ff
Jan 08, 2012 | Ryobi Garden
Changing the trimming line on a rlh1100
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ii
Dec 31, 2011 | Ryobi Garden
I have ryobi 137r . i cannot ge the head off to replace the string
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,don't forget to give 4 thumbs up,any comments welcome,thank you, ``
Dec 23, 2011 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
How do I wind trimmer line on double spoools for ryobi
Good Ruck,
Mark
Apr 09, 2009 | Garden
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
Aug 31, 2007 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
