Question about Logitech Webcam
Hello sir, I have a minor problem with a iball USB mass storage device of 2GB. I ma unable to Delete or copy any thing in the device as it Displays on doing so a statment that " Disc is WRITE PROTECTED please remove the WRITE PROTECTION. I have no idea how to do it would be thankful if you could help. doc.himanshushukla@gmail.com
    President:
  • 414 Answers
Though, i gotta know of os platform u r using..
n assuming that u hv enough/sufficient space left on ur c: or system root drive..n using ram more than or atleast 512mb..n directx installed..
try updating itz firmware..
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i preferavg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6) disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->start up n recovery->(uncheck on the) Automatically Restart;
b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
contact ur system admin/vendor....
Posted on Nov 17, 2009
Can't remove write protection from my kingston datatraveler 4gb g2
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have Data traveler 102 8Gb of Kingston.I used the usb for 1 year.But when i formate it with out keeping in view the formate options the formated with volume 4096 bytes.And when i copied files into the...
You will have to be the computer administrator to change any values on a hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
- Click permissions
hope this helps
Apr 23, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HOW CAN I REMOVE WRITE PROTECTION ON MY USB DRIVE
also
- Click permissions
hope this helps
Mar 31, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cannot remove write protection from my Kingston Data traveller
also
- Click permissions
hope this helps don
Mar 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protact 4GB usb formating soluation
also
- Click permissions
hope this helps don
Mar 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove wrote protection
also
- Click permissions
hope this helps don
Mar 01, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb cant save a file anD delate a file because of a write protected? A BRAND OF KINGSTON
also
- Click permissions
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
Sony microvault 2 gb pen drive- can not copy file- I/o device err
My 2gb sony microvault is asking me to format. It is teeling me that it is write protected. How do I format it
Apr 16, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Sandisk cruzer thumb drive
This just means it is trying to recognize the device. All you need to do is allow it to recogniz the device and find the proper drivers. You can put files in here by going into my computer and double clicking the mass storage device. Files can be draged or copied in here, then taken anywhere you need to go.
Feb 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Logitech Webcam Logo
95 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
