Question about Sharp AR-5320 Black and White Copier
What is code H or 4 which stops copying - Sharp AR-5320 Black and White Copier
  • Sharp Master
  • 1,297 Answers
Your problem in the fuser unit.Please check and clean the fuser lamp,fuser thermistor and thermofuses.Verify the continuity the fuser unit parts( 6-7 Ohm).
Posted on Nov 17, 2009
Download Cannon resetter for error code 5B00 model MX416
FIRST STEP : ENTER SERVICE MODE
<Service mode operation procedures>
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the
buttons). The COPY button lights in blue to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each
time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in blue, starting
with Alarm LED.)
4) When the COPY button lights in blue, press the Stop/Reset button 4 TIMES
SECOND STEP : DOWNLOAD THE FOLLOWING PROGRAM.
www.4shared.com/get/zc4OMn2_/Service_tool_v3400.html.
1. Run the program
2. Set the region according to your location, then klik set
3. klik set on the Ink Absorber Counter
4. Prepapre 1 sheet of paper.
THIRD STEP : TURN OFF YOUR PRINTER AND THEN TURN ON AGAIN.
FINISH
Sep 06, 2012 | Canon Office Equipment & Supplies
I cannot fix the problem Error code 2 & 7
Manual Reset for Canon Pixma MPC190 Printers
1. Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2. Choose TEST MODE.
3. Select 8 PRINTER TEST -TEST MODE.
4. Choose 3, EEPROM CLEAR
5. Select 0, INK COUNT
6. Press the Set button.
7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Aug 11, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How do i program a new number on the fax machine
1. Press [Menu]. 2. Use ^ to select <TEL REGISTRATION>, then press [Start/Copy]. The LCD displays <1-TOUCH SPD DIAL>. 3. Use ^ to select <CODED SPEED DIAL>, then press [Start/Copy]. The LCD displays <*00>. 4. Use ^ to select the two-digit code (00-59) under which you want to register the number, then press [Start/Copy] twice. 5. Enter the party's number and name. 6. To assign additional coded speed dialing numbers, repeat step 4. To finish, press [stop].
Aug 16, 2010 | Canon FAX-JX200
Code 015 Problem
Press
Function
7
tel/dial slowly 4 times
1 for off
stop
stop
Aug 11, 2009 | Panasonic Panafax UF-333 Plain Paper...
Error code=620
Hello sir; Follow the following steps to reset;
1, press these three keys in order and keep hold them down,"stop/reset", "start", "left copy density key".
2, press "stop/reset" key again.
3, enter 163, then press start key,
4, after they running, press "stop/reset" key.
5, press 001 to exit.
Mar 15, 2009 | Copystar CS-1505 Copier
4 digit acces code
First, enter the tech rep mode:
moz-screenshot.jpgPress the Utility key, then the meter count button on the touchpad.
Enter "Stop - 0 - 0 - Stop - 0 - 1" on the keypad. You will enter the tech rep mode.
Select "Administrator # Input." Note this number, or change it to something you can remember.
Now, go back to the Utility screen and select "Admin. Management." Enter the code you just learned, select "Copy Track Mode," and change it to "Off." Exit the mode and you're good to go.
Alternatively, you can select "Copy Track Data," and note the access codes (or enter new ones).
Nov 26, 2008 | Konica Minolta DiALTA Di200 Copier
Canon MP180
That error code is described below:
Error Code Error indication Error condition.
5B00 Waste ink full H/W fail Replace printer.
And i would like you to refer to www.feedroller.com/Store/Service%20Manual/S100sm.pdf
Thos document has all the error codes and what needs to be done for that.
Hope my info is useful,
Thanx for using fixya.
Sep 26, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Canon MP130
0.gif Re: CANON WASTE TANK RESET CODES for Canon MP130 by tac (2/15/07 1:52 PM) reply + / - CANON MP130
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will include printer.
2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and advance value equal to zero.
5. select SET Abs- r level (if there is) and also you will establish into zero.
6. you will turn off printer by button POWER.
Jun 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber -mp500
Service mode operation procedures 1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons. The COPY LED lights in green to indicate that a function is selectable.) 2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.) 3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in green, starting with Alarm LED.) 4) When the COPY button lights in green, press the Stop/Reset button 4 times. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in green, starting with Alarm LED.) 5) Press the ON/OFF button 2 times. You're good to go! Bear in mind that if the ink absorber is full then you risk getting ink everywhere! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 31, 2007 | Canon Pixma MP500 All-In-One InkJet...
Sharp AR-5320 Black and White Copier Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
