Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Is it possibel to re-set setting back to factory settings as my screen is a blue-green?? JM01-22E1-000G hannspree i moved it in to other room turned it on and all buttons were locked,i then after 1hr unlocked it but now more screen is funny blue-green ?
  • 81 Answers
Yes, It is possible to reset setting of Monitor i.e. Degaus
I hope that this has been very helpful for you
Posted on Nov 17, 2009
The foron screen dont show dvd - only show a blue screen. It seem to a conflict in the system as it react very slow Is it possibel to reset the system?
HELP! DVD player/video mode blue screen ONLY! - DVD Talk Forum
forum.dvdtalk.com > DVD Discussions > DVD & Home Theater Gear
Jul 26, 2005 - Windowless vans do NOT have candy, only. When I click on the set up menu, all I see is that blue screen and the green VIDEO in the ...Missing: foron
Help please--DVD/VCR combo blue screen - The Mac Resource Page
forums.macresource.com/read.php?1,653657
Jan 23, 2009 - 19 posts - ‎4 authors
I hope this does not mean that the video channel on the player is ... TV and see where you have the inputs from the DVD/VCR plugged in, if you don't know. .... viewing andonly turn on the JVC when I want to use it for a movie.Missing: foron
Sky HD box just showing blue screen...?! ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Feb 03, 2016 | Cars & Trucks
How do I reset to Factory Settings?
Hello Julie,
Do you own a Hannspree touch screen monitor or normal computer monitor? Either way, click below and you will find directions on how to accomplish this.
Good luck! http://www.hannspree.eu/en/faq-tvs-monitors
http://www.hannspree.eu/en/faq-touch-monitor
Mar 24, 2015 | Hannspree HANNS Computers & Internet
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
SONY PROJECTION TV TROUBLE SHOOTING BLUE SCREEN
This was one of several Sony models that had bad picture tubes--the set uses a red, green, and blue tube.
There is something easy you can try that may help you get some more life from the set.
SONY SCREEN ADJUSTMENT:
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
If it works you may only be buying some time--if the blue tube caused this it may return at some point.
If all this information has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 20, 2009 | Sony KP-51HW40 51" Rear Projection...
I just bought this tv, and have a 3-d appearance on the screen?
If the unit has been moved or jolted, you can usually use the correct factory remote and access menu settings and look under color. You are looking for an alignment setting. In many cases by using the remote in this menu/settings mode on your t.v., you can re-align the red/ green /blue colors into the correct setting. There may also be a re-set to factory settings that you can try.
Oct 13, 2009 | Televison & Video
Getting a red, green, and blue screen when trying to hard reset
your going to have to download a recovery.img of the stock rc29 system and boot that up from that screen. This will hard reset the phone and then from there you can upgrade back to your desired rom.
Jun 27, 2009 | HTC G1
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
482 people viewed this question
Top Hannspree Computers & Internet Experts
richie46
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
