Question about Laser Logitech O - V450 Nano Cordless Mouse - Lt Grey
Hi Mouse Not responding
Hi
I can't seem to get the cursor to go where I want it to go. Having problems with the left & right click sometimes too. Not responding too well?????!!!! Not too sure abt the model #. It just says logitect laser.
Please help. Thks
  • jenny166 Dec 01, 2009
    For God sake I have tried 2 other wireless and 1 usb mouse, same problem. The curser lags and jitters, I have also noticed that the clock is loosing time. My system is a Sun W1100z running AMD Opteron Processor 144 - 1.8GHz and 2 GB RAM
    President:
  • 414 Answers
Common problem of either the surface or the mouse, get replaced with a standby..!!
however, to b in safe hands, check the following:
the Hardware part:..
1) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink*** fan..resit/fit it tightly in position..if necessary change the fan..
5) on main/motherboard..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i preferavg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6) disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->start up n recovery->(uncheck on the) Automatically Restart;
b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
contact ur system admin/vendor....
Posted on Nov 17, 2009
  • Subhradip Chakraborty
    Subhradip Chakraborty Feb 17, 2010
    anyways..it seems dat ur mouse is likely 2 b faulty..
    but it also take place in cases of faulty ram or m/b (i/o controller ic or circuit)..plz do follow the point 1 & 5 of the hardware part as well..
    2 b on safe side it always better to hv a prevention, which is howevr better than cure, as per the expert doctor..!!..a torn shoe howevr can lead to a gangrene, if nt cared..!!..4 the expert doc guesses that people r here in severity n d doc shld guide them at anyways n at all possible corners..the points above r all sensible n fully reasonable..again 4 d doc observes dat d 'CRITIC GUY/GAL' is somehow physically blind or handicapped as he cant find or read what has been written right at d top of d post by the 'expert doc'...."common problem of either the surface or the mouse, get replaced with a standby..!!"....try 2 do ur own work..put ur own experience n b onto point..plz donot poke others..itz not at all gentlemanship..!!..itz a disease..better consult an expert doc..!!
  • 460 Answers
Click on control panel click on mouse to see if there is something you can do to make your mouse a little more responsive.. i had a logitec also and they are a bit-t-c-h to use. also make sure the reciever the part that plugs into the pc is in a light colored spot or surface the same for the mouse. a sheet of printer paper will work.. laser mice do not like a dark surface..to much light absorbtion...good luck bye.
  • 7,993 Answers
For God's sake the problem is with the mouse. The FIRST thing to check is to replace it with another mouse and see if problem disappears. Yet the guy/gal is talking about dismantling the computer. It is like somebody complaining about his shoes and the expert doctor tells him he needs to undergo a quadruple bypass surgery. Be reasonable man give sensible advice.
Posted on Dec 01, 2009
How do I Copy and Past ?
Cut and paste is as simple ah highlighting the word by holding the left mouse button down and dragging over it and then right click on the page and select copy OR you can highlight and use ctrl c to copy and ctrl v to paste
Jan 03, 2017 | Office Equipment & Supplies
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
Mouse buttons left right switching sticky keys
Remember you can always use the keypad in place of the mouse. Try replacing the mouse with another one. If that doesn't work, it is probably something in the software. Do a scan on the system next.
Jan 31, 2013 | Microsoft Computers & Internet
Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
Jul 29, 2010 | Logitech Cordless Mouse
Acer Aspire Netbook..Can't use keys or right/left click.
go to control panel then mouse properties you will see the buttons the left & right then click the task that you want to do.
Aug 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
''do not smoke'' symbol for mouse cursor
Go to COntrol panel. Take the option mouse then choose pointer option. From the drop down menu choose windows default.
Mar 24, 2009 | Computers & Internet
Left click for mouse does not respond - right click very slow
replace the keyboard with one from eBay that would be the least costly way to repair the problem. sounds like the cable has been damaged for the keyboard to motherboard interface. have you tried connecting a mouse to the usb port or the ps2 port on the back? that may solve the problem if you don't want to replace the keyboard
Apr 24, 2008 | IBM ThinkPad T40 2373 Notebook
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Laser Logitech O - V450 Nano Cordless  Mouse - Lt Grey  Logo
521 people viewed this question
Top Laser Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Robin Hill
Robin Hill
Are you a Laser Computer and Internet Expert? Answer questions, earn points and help others
