Question about Samsung SCX 4521F All-In-One Laser Printer
Unit switches off automatically - Samsung SCX 4521F All-In-One Laser Printer
  • 241 Answers
Contact service centre
Posted on Nov 19, 2009
I have a 2002 yukon xl 1500 slt 5.3.I'm having problems with my abs control module and also a code of p1810.Do u have any suggestions as to what I can do?Help I'm low on cash
Melisssketer,
The P 1810 code is usually the transmission, here are some possible causes;
- Faulty automatic Transmission Fluid Pressure (TFP) Manual Valve Position Switch
- TFP Valve Position Switch harness is open or shorted
- TFP Valve Position Switch circuit poor electrical connection
The automatic Transmission Fluid Pressure (TFP) manual valve position switch consists of five pressure switches (two normally-closed and three normally-open) and a Transmission Fluid Temperature (TFT) sensor combined into one unit. The combined unit mounts on the valve body. You could have a problem with any one of these switches. If this is the problem with your car, parts will not be cheap but it can be done without pulling the transmission. I hope this helps, Ray
Feb 15, 2015 | 2002 GMC Yukon XL
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
How do i switch from gas to electric?
Press the automatic mode switch on the upper control board to turn the automatic mode off. This will place the unit into LP operation.
Jun 24, 2014 | Dometic RM2652 Refrigerator
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
My yamaha_rx-v457 is automatically switching off when i turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 21, 2012 | Yamaha RX-V457 Receiver
My car A.C is automatically switching off and ON
Most times, you are low on "Freon", your a/c unit needs to be re-charged.
May 10, 2012 | Skoda Octavia Cars & Trucks
Philips DC912/37 will not pair with the subwoofer. I have had the device for 2 years, and the subwoofer stopped working recently, and now it will not pair with the tuner.
This worked for me. Try it and it should work for you all as well..;-)
Frequently asked questions See all FAQs Question How do I get the main unit to recognize the subwoofer? Answer Wireless connection will set up automatically when you switch on both the main unit and subwoofer.
Sometimes you may encounter the problem that the main unit does not recognize the subwoofer. Try the following process to solve the problem:
  • They are heavily interfered by other wireless home appliance such wireless network, TV etc. Move the subwoofer to another place, the main unit will auto detect & recognize it.
  • Switch off the main unit and the subwoofer and then switch on them again. The main unit should recognize the subwoofer automatically.
If neither of the above works, try to pair with them manually.
  1. In standby mode, press and hold the 090518075138_27245.gif button on the main unit (PAIR flashes on the display screen.) to activate signal transmitting.
  2. Press and hold the PAIR button on the rear of the subwoofer (You will find the LED indicator on the subwoofer flashes in blue and green alternatively) to activate signal receiving.
The wireless connection will set up automatically and the main unit should recognize the subwoofer now.
Dec 21, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
How can i pair my subwoofer to the main unit
Oct 13, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
Cant find on off switch, seriously
there is no switch on that unit. the unit will automatically start when it gets plugged in.
May 09, 2009 | HP LaserJet 3330 All-In-One Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
