Question about Behringer Pmp3000 16 Channel Audio Mixer
Trying to connect a PMP300 to 2 passive speakers. Output A&B are connected, input via RCA on chan 9/10. Sound only coming out of L speaker. Level seems ok and clip level showing L&R feeds.
  • Behringer Master
  • 5,603 Answers
Check that the slide switch is up in the MAIN L and MAIN R position.
Check that the PAN pots are all CENTERED.
Posted on Nov 18, 2009
What is the simplest way to connect speaker to radio?
Hi Micah, What Amp and leads do you have? Your passive speaker will need to be plugged into your amp speaker outs , and you radio into your Amps Tuner/Radio input or Aux, but just depends what system you have. Check what inputs and outputs your amp has and what leads you need as a lot of systems need different setup and cables/leads.
May 20, 2014 | Peavey SP2 PA Passive Speaker
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 26, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
229 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
