Question about Apple iPod touch
My itouch says its playing but i dont hear the music playing. i switched the headphones so i know its not that. what do i do?
  • 7 Answers
SOURCE: Jack on headphones broke off in my iTouch
You might be able to get it looked at under warranty if it's less than a year old.
Otherwise, have a look at this:http://www.ifixit.com/Guide/First-Look/iPod/iPod-Touch You'll need some tools to do it, but they can be bought from the iFixIt site.
If it's jammed in there really badly you might need to replace the headphone jack itself, which may be part of the logic board. Could be a pretty expensive repair job if you choose to DIY. I'd definitely see if Apple will fix it either under warranty or for a fee. Much easier.
Anyway, iFixIt has all the parts for the iPod Touch here: http://www.ifixit.com/Products/Touch-1st-Gen/132
Posted on Dec 09, 2008
IpodTouch94
  • 26 Answers
SOURCE: itouch music problem
i think its the  music its most likely a bad quality of music try other songs
Posted on Jan 14, 2009
marketex
  • 371 Answers
SOURCE: iTouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Posted on Apr 16, 2009
  • 27 Answers
SOURCE: ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Posted on Dec 24, 2009
  • 192 Answers
SOURCE: itouch speaker playing while headphones are connected.
1> Disconnect the ear buds from the itouch
2> Reset the ipod - by holding down the sleep wake button and the home button at the same time until you see the apple logo - the ipod will reboot
3> reconnect ear buds mace sure they are flush with the top of the unit ( no gaps )
play a song to test
**If it is still playing out of both - call apple for repair or go to apple store
Posted on May 16, 2010
I want to play my music from my itouch on my Aiwa NSX-TR77 system (because of the speakers) but do not know how to, or if this is even possible to do so?
It is in fact possible... you can play whatever source to whatever sound system with the correct cable... you need a cable with at one end a headphone output connector (compatible with your Itouch) to an input of your choice on the Aiwa system... usually RCA input (RED & WHITE RCA type connectors) at the other end of the cable...
Cheers!
Aug 31, 2011 | Audio Players & Recorders
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
I do not have any volume in the headphones i dont know how to turn them on or something please help me on how i can hear stuff like youtube videos or something.
Did they ever work or are you trying them on a new computer? They don't need switching on you just plug the plug into the audio out of your sound card or motherboard, make sure the mute button isn't selected on the inline remote. Play an mp3 on your computer, make sure the volume on your computer is turned up, plug in another known working set of headphones or active speakers make sure you can hear the music, then plug out those speakers and then plug in the headphones. Do they work when you try that?
Jan 13, 2011 | Microsoft LifeChatâ„¢ LX-3000 Headset
Have a new Itouch 3rd gen. The speaker used to work but after I plugged in the headphones for the 1st time I could no longer hear the music through the speaker if I wanted to listen without the headphones....
That happened to me once. I just messed around. I turned it on off and plugged it in and out and messed with the volume. I was doing this a lot until it came back on (dont worry, when it happened to me my heart was racing and i was freaking out.) it will go back to normal one way or another.
May 18, 2010 | Apple iPod touch
ITouch 2nd g only plays music throuhg left side of all headphones
expensive remedies
Apr 16, 2009 | Apple iPod touch
The audio
its probably the headphones: on of the sides has died. try different headphones. maybe a new brand would help too. DONT buy expensive earbuds, they break too easily. and dont wiorry, this happens to me all the time because i play with the wire when im listening..
Apr 03, 2009 | Audio Players & Recorders
When I put my earbuds into my ipod touch only one side works
i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
Feb 14, 2009 | Apple iPod touch
Apple i touch 8 gb speaker not working
maybe u have the 1st gen itouch. the 1st gen itouch doesnt havent speakers. Your friend probably have 2sec gen which has speakers. If u look at each other's itouch carefully, u'll notice a slight difference near the edges. your friend's itouch's edge is probably curved like in the 2sec gen one while urs probably isnt.
This answer is my best shot at helping ya. Good Luck!
Shocker2cool
Jan 09, 2009 | Olympus Camedia D-425 / C-170 Digital...
Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
