Question about Nortel 1140E
Nortel IP Phones I2004 and 1140e lose connectivity
Our IP phones lose connection and does re-connect to the Sig. server. They will go through the retry and then says DHCP server unreachable. We have separate subnets and VLANs for the IP phones. We are doing Full DHCP, 802.1Q. We have verified everything on the network switches, power, Portfast, available IP address on the DHCP server, lease times are set for 3 months on that subnet,
, a manual reboot has to be performed before the phones come back on-line. It doesn't happen everyday but occasionally. The last time is happen over 100 phones had the issue. We are suspecting there an issue with the DHCP server but not sure... any suggestions
  • 1 more comment
  • Anonymous Feb 27, 2008
    i2004 reboots
  • Anonymous Dec 06, 2008
    WTF
  • Equathza Dec 12, 2008
    I must say we have same issue's here, but this is not the only problem. We also got problems with voice path etc, random virtual office logout's
    Do you happen to have a "VOLO" patch installed for virtual office use?
    Habit-Forming:
    New Friend:
  • 70 Answers
Please read the user manual, it is described there Nortel 1140e manual Download Free Manuals
Posted on Feb 03, 2016
    Problem Solver:
  • 7 Answers
Here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Posted on Feb 13, 2008
What is a level 3 error
This means that the firmware is messed up and need to be reloaded using a TFTP server. I hope this helps. If you need further support you can reach me at: http://www.liveperson.com/nortel-guy
Aug 05, 2011 | Nortel i2004 IP Phone
How to Assign an IP address in Nortel 1648T switches
Add a computer to your network, and install Microsoft Windows Server on that computer, and enable its "DHCP-server" component. Then, this computer will supply IP-addresses for all the other computers connected to your switch.
The switch is _NOT_ a DHCP-server; therefore, you need to add a DHCP-server.
Dec 10, 2010 | NorStar Nortel PASSPORT 1648T ROUTING...
Server unreachable
go to menu --> settings --> network configuration --> server menu and scroll down to server address and give the server ip address and save the settings and reboot
Mar 26, 2010 | Nortel i2004 IP Phone
Server was changed and i have now lost telephone system control
It does if you use a crossover cable plugged directly into the system and set your PC for an address in the same IP range.....
Carl
Sep 16, 2009 | Nortel T7316E 2-Line Corded Phone
CAN'T CONNECT TO WIRELESS PRINTER AFTER VPN TUNNEL CONNECTION
Check the IP segments. Your printer & your machine would be falling in the same IP segment as your job network. Change the IP segment of your pc & printer.
Sep 01, 2009 | Arris SURFboard SBG900 Wireless Router...
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
Missing contact in Nortel 1120E
It depends on what system it connected to. On my BCM450 voicemail must be set up by that individual to see their name in the directory.
Jul 13, 2007 | Nortel 1120E
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Nortel 1140E Logo
2,143 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
