Question about Sony VAIO PCG-K35 Notebook
Sony vaio cr35 power problem
Hi, I got a problem with my sony vaio cr35. It wont power up, the led only blink once everytime I press the power button. I've already tried removing the battery and use only the adapter and vise versa I got the same result. Can anyone knows what to do? Please help me. Thanks in advance
  • Sony Master
  • 3,866 Answers
You might have a hardware failure here. Specially the part when you said you had the same result when removing the battery and just had the AC in. This machine has NO POST this mean Hardware failure specially the blinking light concerns me on the machine health as far as a tech. I would say bring it into the geek squad to confirm my theory it will not hurt for them to take a few secounds to confirm this if there is any warranties I cannot stress this enought use the warranty this is your secure ticket to a fix if its not warrantied I would seriously recommend having the motherboard evaluated it should at least beep but if you do not get a beep this is NO POST hard ware failure. Thanks and please rate you experience with me postivly
Posted on Nov 17, 2009
Testimonial: "thanks for the advise. I will send it to the service center for evaluation. Thanks very much"
Roku 2 remote won't work
If you have a Wi-Fi Roku remote or a bluetooth Roku Remote, the remote needs to be paired with the unit first before you can control the device. To pair the unit with the remote, you can do the following:
  1. Turn off the Roku player for 30 seconds by unplugging the power cord from the power outlet.
  2. Once you have the bouncing Roku on your TV screen, open the battery compartment of the remote and press the purple button there once.
  3. The Led on the remote should start blinking.
  4. Leave the Led blinking and don't press any button on your Roku remote.
  5. Wait for the Led to stop blinking.
  6. Once the Led stopped blinking, try to test any button and see if it works.
Mar 25, 2013 | Roku 2 XS Wireless Streaming Media Player
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Want all region code for Sony theatre player DAV-X1G
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
May 13, 2011 | Audio Players & Recorders
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vaio VGN-CR35 laptop not booting at all. When started, screen is blank and power led turns on, num/scroll/caps keys flashes once, battery and hard disk led turns on once and immediately goes to off....
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 13, 2010 | Sony VAIO VGN-CR220E/P Notebook
Where is the code search button
The power button is used as code search button.
To programme the URC-3021 please follow the steps
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER).
5. To lock in the code, press and release SET.The LED will
blink twice.
6. Your done with programming.
Thanx
Jul 23, 2010 | One For All URC-3021 Remote Control
Hi everytime i open my vaio net book it wont open
Did you try just on battery power alone? Also try powering it up on AC
and the battery removed. When it turns on for a second, do you hear any
beeps?
99.9% of most laptops can run without
a battery.
Jul 11, 2010 | Sony VAIO VGN-AR630E Notebook
Wont start. When pressing Start button lights blink once.
try removing the battery then start with power cord plug in if it works .your battery my be dead.{try this if it starts with no battery .put battery ina cloth wrapup then a paper bag the plastic bag put in freezer over night thaw at room temp then try recharging battery.make shore battery is fully thawed out before charging
Mar 07, 2010 | Sony VAIO PCV-W10 PC Desktop
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
Television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony VAIO PCG-K35 Notebook Logo
310 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
