Question about Microtek SCANMAKER 5900 Flatbed Scanner
How do I change from the OCR setting to the "Save as" setting?
By clicking the black down arrow on the right side of the button that now says, "OCR" it will give you a drop-down menu. The top entry is "SCAN TO". Select that, and you will be back to your original setting.
Posted on Apr 21, 2010
Scan a document into Word
Hello
Notepad uses the file extension ".txt"
You can open this file in Word and then choose "Save As" and change it to the Word format (.doc or .docx).
I would assume the scanning feature is using OCR (optical character recognition) and, after the scan, the default is to save it in a .txt format so it will open in almost any computer.
You can set your computer to use Word to open .TXT files automatically. You would still have to choose the "Save As" and change the format to Word before you can make meaningful editing changes (elaborate fonts, stationary, etc.) as .TXT files have only the most basic formatting available.
Nov 09, 2013 | Office Equipment & Supplies
I am trying to scan documents. when the scan is complete it says that there isnt ocr program installed. i need to get this fixed quick quick
OCR is short for Optical Character Recognition. OCR programs are used for recognizing and telling the difference between text and images on scanned documents to help your computer decide what file format to save it in. Possible solution for this is to download the appropriate software and re-install it on your computer using the recommended settings.
May 25, 2011 | Computers & Internet
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have Canon Lide 60 Scanner. I have to use OCR function to convert printed text to MS Word 2007. I click "OCR" on CanoScan Toolbox, select Black and White (OCR) Scan Mode. Then, it gives me...
Hello
you are doing well, just select MS word program Exe file in C:\program file\Microsoft office\officexx\winword.exe in set option of canoscan.
Then your scan will open in MS Word
Hope it will helps and do rate the solution if so
Dec 21, 2010 | Canon CanoScan LiDE 60
After I scan text, I cannot put it into a Word document, edit, or anything. I have an Epson 2400. thanks I do not have the scanner directions.
In order to scan to word so a document is editable you need to use Optical Character Recognition Software (OCR). You can download free ocr software from www.simpleocr.com Use that software and then either export once scanned to Word or Save as a Word document in the OCR application.
Jan 22, 2010 | Epson Perfection 2400 Photo Flatbed...
CAN i SCAN A DOCUMENT TO MY PC
Yes you can, you must use OCR to do that, OCR means Optical Character Recognition, first you must scan the hard copy and save it as TIFF format and run through OCR reader, take note that convertion is not perfect, you still have to edit words that are not read correctly.
You can download OCR reader on this link: http://finereader.abbyy.com/?gclid=CK6C96aflZ4CFRgbawodiDZ2oQ
Hope this helps.
Nov 22, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I don't know how to scan a document, save it to my computer, work on it and save it again for future use. How do I do that?
You have to install some kind of OCR (optical character recognition) software.
Usualy you will have CD with one of those in the box of your printer, but if you
do not have it, then go to this webpage and download ptogram for OCR.
Basically, OCR program will scan your document, convert it to electronic document
(word, text...) which you can then edit, modify, save and print.
Here is the link to FREE OCR software:
http://www.simpleocr.com/Download.asp
Good luck,
Dr. Milan Cankovic
May 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Internal drs error 1500:c0:3001
Try change the OCR language.
I had the same problem (HP Deskjet F4280, error code 1500:c0:3001) scanning documents with danish language to PDF and OCR language set to English. Changing OCR language to danish solved the problem.
PaulPS
Apr 13, 2009 | Office Equipment & Supplies
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Ocr
fonts wont be embedded when converting a document to OCR. You'll have to change fonts & styles manually... sorry but it has to be done this way..
Dec 06, 2007 | Adobe Photoshop 7.0 for PC
Microtek SCANMAKER 5900 Flatbed Scanner Logo
60 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
