Question about Canon Office Equipment & Supplies
My iR 5000 had an error code E000350-3000. solve this;
I want Binary file COUNTER & SERIAL Board.For Canon IR6570.
Posted on Dec 29, 2009
  • Anusak Keawkau Dec 29, 2009
    I want Binary file In Counter & Serial Board For Canon Ir6570.
    Hi
    OK I can help you.
    >>Counter and Serial Board you fault<<.
    1. Chip In Circuit board Serial you fault or not connect. Please check.
    2. Chip In Circuit board Counter you Not connect or fault. Please check.
    3. And you dose flow low me.
    - Push (* Function) > (2+8) > (*Function)
    - Select Select Select Select Select Select Select
    - TORN OFF/ON POWER RIGHT MAIN
    Problem Solver:
  • 14 Answers
Check dc & printer bord
Posted on Nov 17, 2009
4 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: E000225 & e000019 error code
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
Posted on Nov 10, 2008
  • 57 Answers
SOURCE: Hello can you really help
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Posted on Dec 25, 2008
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
ERROR CODE E000350 001...
This is a fuser/thermistor error. You may have to get it serviced, but try to reset the error code using the following:
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Apr 20, 2015 | Canon imageRUNNER 5000 Copier
My copier is apear code E00014
your machine canon iR5000P your Error E00014 i not solve
Aug 21, 2012 | Canon Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
My iR 5000 had an error code E000004-0000. solve this
Contact a Canon Dealer/Authorized Service. It's either an error that needs to be reset or you have a hardware issue... with some errors, once you get it, it will never go away until you get a technician to clear it out.
Nov 25, 2009 | Canon Office Equipment & Supplies
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
Help me quickly
Scanner home position sensor,faulty scanner error .Switch machine on/off if the error still show you will need a qualified tech to atted to your machine.
Nov 02, 2008 | Riso RZ220 Duplicator
668 people viewed this question
old marine
old marine
