Question about Bosch 85414M 7/8 Inch Diameter 5/16 Inch Cut 4 Flute Laminate Flush Trim Router Bit 1/4 Inch Shank With 7/8 Inch Ball Bearing
SUM 5/16 INCH 7/8 INCH
5/16 INCH + 7/8 INCH = ? INCHES
  • dontbother10
    dontbother10 May 11, 2010
    Who gets credit for doing your home work?
    President:
  • 583 Answers
I DONT REALY UNDERSTAND THE QUESTION BUT --- 5/16 + 7/8 = 1 3/16 0F AN INCH OR
AN INCH AND THREE SIXTEENTH OF AN INCH
DOES THAT HELP ?
Posted on Nov 17, 2009
Column 75" tall, 16" wide and 16" deep. How many sq feet of stone to cover the column and top?
you have a rectangle of of 75 X by16 and you have 4 of those rectangles so multiply 75 X 16 and then multiply the sum by 4
then you have the ends which are squares of 16 X 16 so multiply 16 X 16 Nd then multiply the sum by 2
then add the 2 sums together to get the total square inches of the surface of the object
now one square inch =.00694 square feet so multiply the total sum by .00694 to get the area in square feet
grade 4 maths really
Jan 04, 2017 | Office Equipment & Supplies
I have a fowler IP54 outside caliper micrometer 7-8" that is zeroed out. There are only 2 keys, a mm/in and zero. How do I reset to have it read 7.0 at 7.0?
Generally, micrometers are "zeroed" to a standard -- an object of a known specific length or diameter. If you have placed a 7-inch standard in the micrometer and brought the spindle into proper contact with that standard, and then zeroed the micrometer at that point, it will be properly set to seven inches. Standard micrometer travel is only one inch, and only that range is usually displayed. The user must then add the standard length to the face display or thimble reading to get the "developed" measurement.
Jan 08, 2015 | Fowler Measuring Tools & Sensors
How many 7 by 12 inch rectangles, can be placed in a 100 inch by 66 inch rectangle?
You want the blanket to be 6600 square inches using 84 square inch rectangles. Dividing 6600 by 84 gives about 78 and a half.
Nov 07, 2014 | Home
WHAT IS 22.00MM IN INCHES
There are exactly 25.4 millimeters to an inch, so 22.00 mm is about 0.8661 inches (a bit less then 7/8 inch).
Sep 20, 2014 | Optics
What is the dimension of rectangular prism with volume of 40 cubic inches
There are an infinite number of solutions.
It could be one inch by one inch by 40 inches, two inches by one inch by 20 inches, two inches by two inches by ten inches, four inches by one inch by ten inches, four inches by two inches by five inches, etc.
Any three positive numbers which multiply together to 40 will be a solution.
May 22, 2014 | Office Equipment & Supplies
Adjoa is three years older than her brother Kwame.seven years ago,the sum of their ages 13years.calculate the sum of their present ages.
Let Adjoa's age be x and Kwame's y.
  • Adjoa is 3 years older than Kwame: x=y+3
  • Seven years ago sum of their ages was 13: (x-7)+(y-7)=13
  • Now you substitute first equation into second equation: (y+3-7)+(y-7)=13
  • 2y-4-7=13
  • 2y=24
  • y=24/2=12 years
  • x=y+3=12+3=15 years
  • sum of their present ages is x+y=12+15=27 years
Sep 27, 2011 | Office Equipment & Supplies
What size npt thread is the adaptor
Common American National Standard Pipe Taper Threads
  • NPT - National Pipe Thread Taper
  • FPT - female (internal) National Pipe Taper threads
  • MPT - male (external) National Pipe Taper threads
  • NPTF - Dryseal American National Standard Taper Pipe Thread (ANSI B1.20.3)
For NPT threads a sealant compound or Teflon tape must be used for a leak-free seal. For NPTF no sealant is needed for a sealing.
Characteristics of NPT (also known as ANSI/ASME B1.20.1 Pipe Threads, General Purpose):
  • tapered thread 1o 47'
  • truncation of roots and crests are flat
  • 60o thread angle
  • pitch is measured in threads per inch
Note! Pipe sizes do not refer to any physical dimensions. The outside diameter of a pipe or fitting must be measured and compared to a table for size identification. A 3/4" NPT pipe thread has an outside diameter - OD - of 1.050 inches.
Each thread size has a defined number of threads per inch - TPI, or pitch. The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because more than one size have the same TPI.
NPT - American Standard Pipe Thread Taper 1) Pipe Size
(inches) Threads per Inch
TPI - pitch Approximate Length of Thread (inches) Approximate Number of Threads to be Cut Approximate Total thread Makeup, Hand and Wrench (inches) Nominal Outside Pipe Diameter
OD
(inches) Tap Drill
(inches) 1/16" 27 0.313 1/8" 27 3/8 10 1/4 0.405 R 1/4" 18 5/8 11 3/8 0.540 7/16 3/8" 18 5/8 11 3/8 0.675 37/64 1/2" 14 3/4 10 7/16 0.840 23/32 3/4" 14 3/4 10 1/2 1.050 59/64 1" 11-1/2 7/8 10 9/16 1.315 1-5/32 1-1/4" 11-1/2 1 11 9/16 1.660 1-1/2 1-1/2" 11-1/2 1 11 9/16 1.900 1-47/64 2" 11-1/2 1 11 5/8 2.375 2-7/32 2-1/2" 8 1 1/2 12 7/8 2.875 2-5/8 3" 8 1 1/2 12 1 3.500 3-1/4 3-1/2" 8 1 5/8 13 1 1/16 4.000 3-3/4 4" 8 1 5/8 13 1 1/16 4.500 4-1/4 4 1/2" 8 5.000 4-3/4 5" 8 1 3/4 14 1 3/16 5.563 5-9/32 6" 8 1 3/4 14 1 3/16 6.625 6-11/32 8" 8 1 7/8 15 1 5/16 8.625 10" 8 2 16 1 1/2 10.750 12" 8 2 1/8 17 1 5/8 12.750 14" 8 14.000 16" 8 16.000 1) The taper is 1/16 inch in an inch, which is the same as 3/4 inch in a foot (angle 1o 47')
NPT threads are not interchangeable with NPS - National Pipe Straight - threads.
NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different.
Feb 28, 2011 | RTO 1 1/4" Drop Pipe Bronze Pitless...
Continuous paper jam when i try to print
Hi ,
Follow the steps below -
1. check the media / paper compatibility. It sould be as per hp :
Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
A5 148 x 210 mm
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
127 x 178 mm (5 by 7 inches)
Letter: 216 x279 mm (8.5 by 11 inches)
A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
ISO A5
JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards.
4.open the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
5. make sure you replace the cartridge if its refilled. It could provide obstruction.
move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
Apr 08, 2008 | HP Officejet 7210 All-In-One InkJet...
Bosch 85414M 7/8 Inch Diameter 5/16 Inch Cut 4 Flute Laminate Flush Trim Router Bit 1/4 Inch Shank With 7/8 Inch Ball Bearing Logo
157 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
