Question about Sony VAIO VGN-NR285E/T Laptop
The WLAN off and on switch is not being recognized. The switch is located on the front of the laptop case. off and On. I have checked the setting/advance setting and network connection button. Ran system diag. on system, comes back as working properly, just that I need to switch on the WLAN switch. I have clicked on and off of the switch. For three days now, still the switch is not being recognized.
  • Sony Master
  • 3,866 Answers
I would try a system recover before the last ditch effort in replacing the card itslef inside the unit. I would excersize all warrenty policys from sony before trying to attempt the fix yourslef if its out of warrenty try a system recovery if that doesn ot shore up the issue replace the Wifi card there is nothing else I could bring up to try at this point. Please do leave postive feedback ether way for your free answer today.
Posted on Nov 17, 2009
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
How to switch on wlan ?
You can turn ON the WLAN in two ways. The most common way is by flipping the physical WLAN switch ON. The switch is usually located at the front side of the computer (look below the light indicators at the bottom of the touchpad or at the left / right / side of the computer. On some computers, they're above the keyboard.
If that won't work, you might wanna try a combination of function key (Fn+ wireless key).
For Toshiba laptops it's Fn+F8, and for Lenovo it's Fn+F5, Dell and HP usually uses Fn+F2 but every brand has a different combination so check the F1 up to F12 keys for the wireless symbol.
Cheers,
Sep 02, 2011 | Computers & Internet
Toshiba satellite L500-1R0, fn hotkey is not functioning to on the wireless of the system. please help with the software i can download to to use it on my system wireless on.
Hi, have you tried the front wlan switch? It is located at the front of your laptop and usually will resolve the problem. If it is already on, then turn your switch off and then on. Also double check the function key to make sure that it is on. If it still doesnt work, you will need to start checking other things such as drivers, and if the drivers are there, then it could be a wlan card failure. To check the drivers, click on Start>>right-click on Computer>>left-click on Manage. On the left, click on Device Manager, and under the heading of Network Adaptors, see if there is anything corresponding to your wlan adaptor. If there is nothing like this, then your card seems to have failed. Otherwise, a yellow exclamation mark indicates a driver problem. In this case of a driver problem, right click on it, and then click on uninstall. Restart your computer and see if the wlan works. Failing all of that, it would point to a wlan card failure. Hope this information helps
Nov 06, 2010 | Computers & Internet
Where is the wlan switched located?
it located as on/off slider on side of your laptop.
Feb 28, 2010 | Dell Inspiron 1545 Notebook
Wlan not connecting
Its possible that your wlan switch is set to the off position try to find a wlan switch and slide or press the button to turn wlan on.
BTW Sony has the wlan switch on the right side, Acer usually has the switch on the front HP has a button on near the keyboard Compaq also has a button near the key board
Sep 17, 2009 | Sony VAIO VGN-FZ250E/B Notebook
How do you switch on 'wireless connection'?
The Wireless Lan Switch should be on the right hand side of your laptop near the front. After turning this on the WLAN indicator should illuminate which is located in the middle of the front side of the laptop.
regards Richard.
Sep 01, 2009 | Sony VAIO VGN-N250N/B Notebook
Laptop no longer recognizes wlan card
http://www.fixya.com/Unanswered.aspx?ctgid=8
Jan 09, 2009 | HP Compaq nc6000 Notebook
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
Dec 20, 2008 | Computers & Internet
WLAN switch button does not work
Locate your wireless card compartment on your computer. It is probably on the back of it. Your computer manual should tell you where it is. Open the compartment and locate your wlan card. Remove it from your laptop for about 30 seconds, and then reinsert it and make sure that the proper connections to it are firm and secure. Close up the compartment. Turn on your laptop. Your laptop should search and recognize it. If it doesn't, then your wireless card probably quit working on you. If your computer is still under warranty, and if it doesn't recognize it after you have tried this, then you can contact your computer manufacturer and explain to them what happened. They should replace your wireless card at no charge. If you bought the wireless card from some other store, then take it to them and explain to them, and ask for a replacement wireless card.
Sep 04, 2008 | Averatec 3200 Notebook
Sony VAIO VGN-NR285E/T Laptop Logo
184 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
