Question about RIM BlackBerry Storm 9530 Smartphone
NEED BLACKBERRY STORM DEFAULT RINGTONES
Synced my blackberry 9530 last night...and the default ringtones disappeared. Any place to download them. (Getting REAL tired of Blackberry Desktop Software gliches like this)
I have a blackberry storm 9530 but network's is blocked ,when i'm typing (mepd,mep2)to unlock network's nothing happning!
You need blackberry storm 9530 unlock code to unblock your phone. Try to call your network provider and make request to them about blackberry unlock code, you also need to pay some charge from your provider. But if you want instant unlock code you can get that from third party sites with less charge.
Aug 27, 2011 | RIM BlackBerry Storm 9530 Smartphone
I have a black berry storm 9530 for verison but i have to use it in nigeria but i cant perform simple network operation like rechargeing *123# and other command. i get the number unobtainble message on...
Hi sir,
i think you need to contact your service provider so they can set up a necessary settings for your connection if you're going to other place..thanks :D
Apr 14, 2011 | RIM BlackBerry Storm 9530 Smartphone
How can I syn msn contact wih the blackberry storm without outlook
You can't directly. But you could possibly use Google sync indirectly to somehow copy contacts to both places.
Feb 02, 2010 | RIM BlackBerry Storm 9530 Smartphone
Unlocked Blackberry storm 9530 EDGE issues. Rogers network
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues like this.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 09, 2010 | RIM BlackBerry Storm 9530 Smartphone
I need unlock code for a blackberry storm 9530
Go to service centre ,, provide authentication,, they'll do the required setting.
Sep 23, 2009 | RIM BlackBerry Storm 9530 Smartphone
BlackBerry Storm 9530 Network Blocked
My BlackBerry 9530 network is block.and MEP check failed. How can i do pls pls help me
Sep 17, 2009 | Cell Phones
After storm update lost default ringtones
You can reinstall the entire system on the phone or better yet download some good tones.
Check out http://www.exectones.com/
Jun 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
HELP WITH VERIZON BLACKBERRY STORM 9530
crackberry.com if the app is available they will have it for download
Mar 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
Downloading Text Messages on my Blackberry Storm
No, you can't do this. The BlackBerry stores your text messages in a database file that isn't compatible with anything other than itself. The only way to get your texts off of the device (in any kind of read-able format), is to forward them to another phone.
Mar 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do I set a ringtone for ALL contacts
Go to the ringtone or music and Open Menu then select Set as Ring Tone!
Hope this can help.!
Best regards,
Julio de la Cruz
Jan 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
1,095 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
