Question about GPS
It wont keep a charge, the battery dies way to fast, it wont charge it with the cigarette lighter, or the house charger. once i unplug it it dies. I replaced the cigarette lighter and the home charger, and that still did not work. I think i need to replace the battery, but it doesn't tell you what kind of battery it is, or how to take it out the battery was put in there in Jan.5th 2008, and I got it around June 2008 at a Sharper Image store that was going out of business as a birthday present.
  • GPS Master
  • 14,804 Answers
Rechargeable batterries fade with age, neglect or misuse. Your battery is almost 2 years old from the time you purchased it, (probably 6 to 12 months older), so could indeed be dying. I just replaced a phone in my cell phone that was holding a charge for less than a day. The replacement from batterybuyer dot com fixed the problem and now my phone stays charged for 3 to 4 days.
Open the case of the GPS unit and the battery will have its specifications marked on it, usually a serial number and voltage, plus capacity in Milli-amp hours.
Posted on Nov 17, 2009
The battery on my 1194 S420 needs to be charged. I can't open the truck to get to the battery. What do I do? HELP!
You can buy a trickle charger that will charge the battery through the cigarette lighter socket, but it won't charge the battery quickly. I'm guessing that the "1194" should read 1994. Some newer cars won't work with a cigarette lighter charger.
If you have a manual transmission you can actually push start the car by getting it rolling, putting the ignition in "run", and then popping the clutch. Not something that you can do if you haven't seen it done before, though.
Best wishes and I'll keep my fingers crossed that it works out.
Jan 31, 2011 | Mercedes-Benz S-Class Cars & Trucks
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
How can I open the luggage compartment of a Porsche 911 when the battery is dead?
The best way to do this is to put battery voltage back into the system through the cigarette lighter. You can buy a battery charger at an auto parts store or walmart that is designed to charge the battery through the cigarette lighter. It will have a plug on it that insert right into the cigarette lighter. Let it charge a little, and try the button again. It will pop right open.
Feb 02, 2010 | 2005 Porsche 911
Battery flat cannot release bonnet to jump start
You have to charge the battery through the cigarette lighter. Go to an auto parts store or walmart and there you can buy a car charger that will plug into the cigarette lighter. Once the battery charges a little, you can pop the bonnet. Once you have access to the battery, you can use a heavy duty battery charger or replace the battery.
Feb 01, 2010 | 2004 Porsche Carrera
Garmin screen is all i get, then it turns off
try changing the batteries or placing the device on charge and unplugging it, if both those don't work go to the support section on garmin's website www.garmin.com/support/
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
Cigarette lighter wont work no more on my 2001 aurora
1st check all fuses. 2nd why do you need to charge all the time? If your battery keeps going low and you have to charge it all the time , perhaps you need a new battery. If the charger has to give the battery a large charge then it may have caused the fuse to fail on that circut. . Is this device for a cell phone? If it is then you probably blew a fuse. Let me know if you are charging the car battery or charging a cell phone battery.
May 09, 2009 | 2001 Oldsmobile Aurora
Zumo wont accept 12v charge from car or bike !
Did you drain the battery completly? Have you tried another battery yet? I've come across this issue once, seems the owner drained the battery completly. Leaving it hooked to the mains with the mains charger for almost a day did solve the issue. I'd try a new battery first.
Oct 19, 2008 | Garmin zumo 550 GPS Receiver
Cigarette Lighter Coming on but power not strong enough to charge anything
the two problems that you posted could be connected somehow by the alternator not charging because of the belt issue. so if you have a low battery, the cigarette lighter would have a low voltage also.
then on the ipod issue, the memory of the radio could have been lost due to removal of battery cables or the battery really went down on its voltage. just re-configure your radio to accept the ipod music.
tnx 4 using fixya,
drcool
Oct 05, 2008 | 1999 Mercury Cougar
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
78 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
