Question about Brother HL 5130 Laser Printer
I have a trouble with Brother Hl- 5130 printer.
I have a trouble with Brother Hl- 5130 printer. All ligts are blinking at the same time. wht can i do?
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
SOURCE: 5240 brother
-Turn Power Off
-Open Front Cover
-Hold down "Go" and "Job Cancel" Buttons while turning on Printer (All lights will stay on)
-Press "Go" button 2x
-Press "Go" button 5x
-Close door and Print
Posted on May 22, 2008
  • 4 Answers
SOURCE: Lost Installation CD for my Brother HL-2040 printer
Go tor HP printer drivers on the net.
Posted on Sep 27, 2008
rscheutz
  • 54 Answers
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Posted on Mar 25, 2009
SOURCE: Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Posted on Apr 23, 2010
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
My printer brother hl-2040 drum light is blinking what is the problem
Time for you to replace the laser drum unit in the printer.
the drum units have a life cycle of about 5000 pages and then need to be replaced. Order a new one from Office Depot and simply swap the units.
Cheers,
Keith
Jan 13, 2010 | Brother HL-2040 Laser Printer
Hey, wht's with this 2 page "manual"?
You may have received the setup poster. This should be the User Guide for your product (manual):
Brother HL-2040 User Guide
Jan 12, 2010 | Brother HL-2040 Laser Printer
Brother HL-1440 LASER PRINTER requires ''Service Call A''.
currently, the error you have is not a service errorl, ready and alarm blink means that you have either a paper jam, no paper, or a paper misfeed.
do you get this error only when you try to print?
according to the service manual the lights can not alternate in blinking.
May 30, 2009 | Brother HL 1440 Laser Printer
Won't print. blinking red paper light flashing
Mar 25, 2009 | Brother HL-2040 Laser Printer
5240 brother
I just solved my similar problem- switch off printer, open front door, hold down go (blue) button. Now switch on, holding the go button for about 10 seconds then closing the door.This left the lights all off, green light only when pressing go. Switch off then on, it worked! hopefully this helps someone else. Ross
Apr 18, 2008 | Brother HL-5240 Laser Printer
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Feb 21, 2008 | Brother HL 1240 Printer
Brother HL 5130 Laser Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
