Question about Dryers
Dryer won't spin. Took front off, belt is tight. When wife tried to start a cycle, it wouldn't start, just gave a soft clicking sound.
    President:
  • 744 Answers
Hello, without a model/make i can only tell you that this is likely to be the thermal fuse. in whirlpools and kenmores it is located in the back of the machine and looks like this. regards Mikedryer won't spin. Took front off, belt is tight. - 109888a.jpg
Posted on Nov 17, 2009
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Frigidaire (LTF2940) Front Load Washer Makes screeching noise during spin cycle, drum does not spin
the belt is either loose or off the drum or the tensioner gave out...please rate me thank you
Aug 10, 2008 | Frigidaire Dryers
Drum won't spin on it's own but spins freely by hand.Was slow to start spinng before. Took front off but can not see belt at all, if it has one?
drive belt is normally accessed from the rear of the machine or if sealed rear from underneath(bottom) the belt is normally easier to get off the drive motor pulley first . Sounds like your belt is either already broken or has come away from drive unit or drum .
Jul 25, 2011 | Maytag MDE508DA Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
My dryer will not start when button is pushed. There is a ticking sound in the back when I push the button to start it
Sounds like you have a broken drum belt. The click you hear is the motor starting and thgen a slight purr is it running.
You will need to secure a belt and maybe a few other parts. You want to remove the cover and see if you need glides and or bearings (\depending on who made your dryer) A list of "overhaul parts list" for dryers include
1 Belt
2 Idler pulley or assembly (keeps the drum belt tight)
3 Front Glides or bearings
4 Rear Glides or support bearings
5 a vacuum to clean out dust and lint while open
6 Inspection of the Fan/blower impeller and clean as necessary.
7 And advantage here you get to keep any change you find.
Hope this helps you. Even if you decide to call someone in for the job He will only partly do it if he just puts on a belt and doesn't show you the conditions of the other parts. Ask him to let you see these parts as he comes to them and help you decide to reuse them or replace them.
Please raste me as high as you can and thank you for using fix ya.
May 29, 2009 | Kenmore 62602 Electric Dryer
Dryer will not cycle
Replace the belt and all will work fine. The belt spins the drum
Feb 09, 2009 | KitchenAid KEYS700LQ Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
