Front right make a clunking noise when stoping
  • 106 Answers
More than likely a controol arm busing or strut need to get replaced
Posted on Nov 17, 2009
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
I have a clunking sound on the right side of my 06 Range Roover, just noticed, what could it be?
Do NOT delay in getting this checked. It may be something simple, but it could also be potentially dangerous. See the articles on the website www.graemecooper.com.au about identifying noises
Jun 22, 2014 | 2006 Land Rover Range Rover Sport
Backing up made clunk noise and when dry sterring it makes a clunk noise when turning wheels left and right
You're probably going to need a shop to look at the front suspension.
With extra weight in the back, the front could have been up enough to cause something to come loose such as a strut mount. And that could happen just from old age without the extra weight.
If it is a strut mount you may not want to change it yourself since the strut has to be removed.
I would suggest getting a couple of estimates, or more. In most cases the shop will want to do a front end alignment too because of having to remove the strut.
Apr 29, 2013 | Cars & Trucks
What can cause a Clunking Noise in right front wheel area when truning wheel to the right when slowly backing up or pulling forward?
If its a front wheel drive more then likely its the half shaft That's a drive shaft on the rt front
Feb 17, 2013 | Lexus IS 250 Cars & Trucks
Front right wheel clunking
Have your struts checked.
Oct 03, 2012 | 2001 Ford Taurus
2000 chev cavalier feels sluggish while driving. as well as it has a faint clunking noise from the front right?
CLUNK NOISE ON THE RIGHT FRONT WHEEL IS WORN OUTBOARD CV JOINT.THE VECHICLE SLUGGISHNESS IS LOW TRANSMISSION FLUID LEVEL OR TRANSMISSION FLUID AND FILTER NEED CHANGING.
Feb 17, 2011 | 2000 Chevrolet Cavalier
I am hearing a low clunk noise from right front
could be cv booth starting to worn out
Jun 01, 2010 | 2003 Honda Odyssey
1998 dodge neon front disc brakes
Does your car have rear disc brakes? If so, it is likely a failure of the emergency brake that is inside the rear disc.
Sep 22, 2009 | 1998 Dodge Neon
Clunking noise in the front right when coming to a stop
first off the alt. belt is too tight. loosen it. should go away. and if its a clunk in the frount end i would guess it is your struts or bushings or both.
Apr 02, 2009 | 1990 Toyota 4Runner
 Grubhead
Grubhead
