Question about Cell Phones
My mobile show LOCAL MODE and doesnt start!
I started charging my mobile. then, it showes NOT CHARGING. I switched it off. and, when I again swithced it on, it didn't go to its normal screen. but it started shownig LOCAL MODE. now, it doesnt start and when connected to the charger, it shows LOCAL MODE. pls solve this problem. thank you.
Good day guys, please help its very urgent. my moms friend downloaded a game and now the phone doesnt charge or switch on even with new battery.
Try pressing and holding the power button to see if you get access to power-on/power-off options, or immediately pressing and holding the power-off button when you turn it on. You are looking for the option to start up in Safe Mode. If you can get into Safe Mode, then you should be able to delete the offending game.
Apr 23, 2016 | Samsung Tablets & eReaders
Yesterday my htc desire was discharged so i pluged it at computer when, but in same time i was using it. In one moment it switched off.. i took battery out and put it in back and switched on but it only...
It would be best to bring your phone to diagnose the problem. It could be a number of things, from software to hardware, so your best bet is to bring the unit to a service technician
Apr 02, 2011 | HTC Desire Cell Phone
My htc touch mobile gts switched off automatically though battery is fully charged and is new.is there a software problem or what?after getting off it doesnt start very easily.again i ve to start charging...
you have a mobile with an isemetric fault its built into the pcb due to bad current draw the only way to fix it is to replace the whole pcb if its new take it back if its under warrenty get it fixed or youl have this trouble for the remainder of the phones life.
this fault normally comes with the phone. it is not a fault that it picks up along the way
best of luck
please take the time to rate this advice
merry christmas
Dec 07, 2010 | Nokia N73 Cellular Phone
Software problem
try to put charger to phone and see whether it shows charging. if it shows charging than you can power on after a while. are if you have removed battery without switching off the phone to change sim card, than most probably your phone's software got crashed and you need to visit sony ericsson service point.
Dec 24, 2008 | Sony Ericsson K810i Blue Smartphone
When battery was full charged no indication was shown by mobile.
Another way that you can see when you're phone is charging is if you turn your phone off and then plug it in to the charger. This will make the phone show you an Animation of a big Battery being charged slowly, if it shows 4 bars all the way to the top your phone is fully charged.
Dec 06, 2008 | LG KU990 Viewty
My nokia 5610 is displaying local mode but then not switching on! When i put my cell to charge , it shows the default blue wavy screen which appears generally when the cell is switched off w/o charge and...
download and install NSS (Nemesis service suite) here is the link.
http://www.b-phreaks.co.uk/index.php?main_page=page_2
1. click the manifying icon on the top right
2. click PHONE INFO
3. click SCAN (it should be in the middle)
4. and then in the power box. you will see 3 option (local, test, normal)
5. check NORMAL and click on change
6. now your phone turn on by itself..
7. GOODLUCK!..
Oct 28, 2008 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Water damaged,not charging--nokia1110 my nokia1110 was water damaged.still after that also somehow it was working bit properly.. then LOCAL MODE msg came in and went away after a while. Later when battery...
Guest - you phone needs to be taken to a professional repair store and have the local mode remove...that is a testing mode when unlocking or service the main-board.
akemsl11 - the fuse could be blown on the board for the charging....either buy a new mobile or take it to a repair store close to you to have them service the phone for you.
arkster101 - take the phone to a mobile repair tech and have them service the charging port and fuse on the main- board but i think the board is gone so you should buy a new mobile.
Apr 23, 2008 | Nokia 1110 Cellular Phone
Lg mobile battery indicator
Have you tried a different plug? Sounds like the plug might be bad. If you have a car charger, and a house charger, I would try both. IF one charges, and the other one doesnt, you have your answer. If you have trouble with both, then either you have 2 bad plugs, or the socket on your phone might be bad.
Either way, your local phone dealer can check them out in seconds, and some places won't even charge.
Good luck
Feb 03, 2008 | LG KG220 Cellular Phone
Cell Phones Logo
293 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
