Question about Brother IntelliFAX 1800C All-In-One Printer
Brother Intellifax 1800C-jamming issue
Paper jams every time, either thru inside back of control panel or thru multi-purpose sheet feeder.
Hamilton McGill
    Problem Solver:
First, check your rollers for a small piece that may be stuck between the rollers causing the jam.
Second, make sure there is not to many sheets in your tray.
Third, make sure that you have not pushed the paper down to far in the tray this uaually makes the machine grab more than one sheet.
good luck
Posted on Jan 27, 2008
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
I understand your frustration. Try this solution.
* Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
* Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
Close the scanner cover.
Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
* Turn the power back on.
I hope this helps you.
Aug 03, 2010 | Brother DCP 1000 All-In-One Laser Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
Action : Remove the paper according to the following procedure.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother fax machine says back cover open and it is not open. Why?
This message comes up sometimes when paper is jammed inside. Remove paper thru back cover.
Mar 05, 2009 | Brother IntelliFax-2820 Laser Fax
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Paper Jam
Hi Art,
Try cleaning the rubber feed rollers with a good grade of isopropyl alcohol.
Make sure the side guides of the feeder are not too tight.
Nov 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2800 Paper Jam Issues
Pull open the doc feeder and look for an obstruction. A wayward staple, paper clip, push-pin, post-it note?
Sep 27, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 1800C All-In-One Printer Logo
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
