Question about Cell Phones
I have a blackberrystorm with t mobile sim card my phone was working fine but now say no circuit channel available
  • 3,741 Answers
Try to reset the device my removing the battery for 30 seconds and replacing it. After the reboots check the signal agian and see if you're getting the same message.
OR
change the conection settings to manual and check if it works.
OR
changing from 3G mode to 2G mode using these steps:
Press 277634#*#
Then go through the menu:
Modem Setting
Network Mode
Network Mode
2G only
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 17, 2009
Sim card problems t mobile
There are two possibilities available to get invalid sim message while inserting Sim on your phone.
1.There may be a problem in your Sim card so try another one.
2.Your mobile is locked to particular network provider.
If your problem persists,Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your TheUnlockSpot.com I hope it will be very useful to you.
Sep 07, 2014 | Alcatel Cell Phones
New sim card and new phone. But nothing works. Is there anything regarding unlock
First ensure through your network provider that the new SIM card has been activated. If not wait for the activation to complete. Everything will be fine.
If the activation has been completed and still if it doesn't work, Insert your SIM card into any other active mobile phone and check whether it works with it. If it doesn't work there is some problem with your SIM card. Contact the seller where you bought your SIM card. If it works fine with the other phone, then there must be some problem with your new phone's SIM port.
Try inserting any other active SIM card to your phone and check whether the SIM port of your mobile phone is fine.
Also make sure that the new phone is free from network restriction or locked to same network of your new SIM card. If it has been locked to some other network, you need to unlock your device.
To unlock a mobile phone from network restriction, you need to enter it's unique unlock code. You can get an unlock code from the respective network provider or from any private service. For example, If you have a Blackberry phone, You can visit UnBBLock.Com to get the unlock code. If you have any other model phone, visit http://www.mobile-unlocker.com/ to get the unlock code at affordable cost with easy unlocking guide. Good luck.
Jun 03, 2014 | Cell Phones
Mobile not supporting indian sim
What is your mobile model?Have you tried the mobile with other Indian sim cards?If you still get the same error then I think your phone is locked with a Saudi Arabian network.You need to unlock it...otherwise it wouldn't accept other networks.You can approach third party unlocking services like Unlock-zone.com and by specifying the mobile make,model,country and network to which the mobile is locked to you will be able to get the unlock service along with free unlock instructions.Once unlocked you will be able to use the phone with Indian sim cards.
If the phone works with other Indian simcards without unlocking then may be there is a problem with the sim card that you are using now.Approach the network provider and get a new sim.
Jun 18, 2013 | Samsung Cell Phones
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
SIM Card Rejected
If the Phone says Sim rejected means it locked to Network,You need to Unlock it,you can get the unlock code from the site
Unlocking4u.com/unlock-your-phone/rs6wp2/ and Unlock it from Network Lock,Then You can use any GSM Network Sim card in NOKIA 1280.
Dec 03, 2011 | Nokia 1280 Cell Phone
Howto unlock a blackberry storm so i can use my net 10 sim card
you can try unlocking your phone through codes. its the safe way to unlock your phone. because when you unlock your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you unlock through codes. thats y i prefer this method to unlock my phone. i got the codes from this site Mobileunlocksolutions.com to unlock my phone you can get the instructions from here Mobileunlockguide.com to unlock the phone.
Aug 25, 2011 | Jwin FLEXIBLE CASE FOR BLACKBERRYSTORM...
I have a Blackberry Storm 9530 put a T-Mobile sim try to use the phone give me no circuit channel avilable
You must unlock your phone first before you can use your t-mobile sim card in that phone. To unlock blackberry storm 9530 network you will need a reliable blackberry unlock code where you can purchase at third parties sites.
Nov 16, 2009 | RIM BlackBerry Storm 9530 Smartphone
Sim card rejected
this happen if there is some problem in the sim card holder port ....
there will be loose contact inside the sim card holder is not touching the circuit board inside due to this your sim card is getting rejected ...
as you have told that the phone is a brand new one so i am sure that you will be having the warranty so just make use of it by contact the dealer with whom you have purchased or contacting the company customer care number to get more information about how to make use of your warranty ......
if you dont have the warranty then you must open the handset
and just remove the circuit board & sim card holder and insert it again so that the sim card holder touches the circuit board correctly ...
after this refit the phone then surely your sim will be accepted ....
it is better to use of warranty if you have ......
this is a simple problem if you dont have the warranty also you can only fix it ..
if you just open the handset & set that sim card holder to touch the circuit board that s enough everything will be done and works fine ...
if you are afraid of opening then you must just contact the technician ...
it is just a matter of very little bucks if you contact him also ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 12, 2008 | Nokia 6230
Sim card rejected
thank you
bye
rate my solution
Jul 09, 2008 | Motorola Mobility C261 Cellular Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
