Question about Lexmark X1270 All-In-One InkJet Printer
PAPER WILL NOT FEED - Lexmark X1270 All-In-One InkJet Printer
    Problem Solver:
  • 5 Answers
Check that everything is in properly
Posted on Nov 17, 2009
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
Feb 07, 2018 | Canon PIXMA Office Equipment & Supplies
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
How do I use manual feed on the brother mfc 7820N printer/fax/copier?
The manual feed slot located in the front of the machine above the paper tray.
  1. Slide the gray paper guides to fit the size of the paper
  2. Using both hands put the paper (side to be printed, face up) in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the Brother machine feed the paper in a short distance.
  3. You must then go to the application that you want to print to the paper and use that application's paper settings to set the paper size, orientation, font, style, etc
  4. Good luck trying...
May 20, 2010 | Office Equipment & Supplies
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
Paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Oct 11, 2007 | Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
